Results 1 to 10 of 10
Thread: Missing VIN
    Jul 2008
    Default Missing VIN
    I've been attempting to upgrade my OS from the current 99 to 02. After the full reflash it indicated missing serial number , but it created one. I also noticed vin is missing?? I've tried full re-flash but to no avail. What did I miss, screw-up, etc???
    1999 5.3L original os--09379910 new--12212156
    What version of software are you running?
    Jul 2008
    EFILive_Tune.exe V7.5.5 (Build 78)
    Jul 2008
    BTW- I decided to do reinstall original OS because of missing vin, everything looked ok. I then did a read of PCM and vin still indicates it's missing. N/A000000000000....
    Try to write your correct vin using the scantool.
    Jul 2008
    Thanks for the reply. I did further research on the forum and I came across one of your old posts with the exact same help. I can do this from the bi-directional controls, right?
    Feb 2006
    You can use the Tune tool, look for the "key" icon at the top of the screen or "Ctrl-Home"
    Al
    Yes on both.
    Jul 2008
    Thanks for the reply's. I'll give them a try as soon as I get a new laptop. My old one gave up the ghost last night....
    Jul 2008
    Thank you for your help, I was able to program vin into pcm.
  1. Another missing PID
    By gmh308 in forum Black Box Logging
    Last Post: September 29th, 2009, 01:00 PM
  2. E38 Missing tables? Or I'm missing something?
    By gmtech16450yz in forum E37, E38 & E67 PFI ECM's
    Last Post: January 7th, 2009, 03:28 PM
  3. PID's Missing or am I missing something
    By dperry in forum Duramax LLY
    Last Post: March 1st, 2007, 03:15 PM
  4. Maybe i'm missing something but... (V2)
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 17th, 2006, 01:32 PM
