Is there any indication if a filter is applied or not?
Where are the filters stored?
97 Vette 6spd, CamMotion Titan2 LS1 cam, TSP 5.3 StageII heads, Vararam intake, Z06 manifold, ARH headers/cats, Z06 catback, Monster Stage2 clutch, 04 Z06 pcv, new style knock sensor(late98 to 04).
Using FlashScan V1 with NGK-AFX Wide band
The filter icon will appear "depressed".
White with a border around it.
LC-1 WBO2
Very subtle difference, especially if the cursor remains on it. Thanks for the tip.
Also if you float the cursor over the filter icon you will see which filter is or will be active.
This will be at the bottom of the screen under the fast forward buttons.
LC-1 WBO2
