Hi all,
on the weekend I plugged in my MAF again (and reflashed with all the necessary changes) to see if the car would do better with the MAF in the cold Michigan weather.
With the SD tune the converter locked up in OD when the transmission temp. reached 68-70deg. F. . Now with the MAF plugged in, until 111degF nothing happened. I couldn't go to any higher temp because the trip was over.
Can anyone explain what happened? Did anyone experienced something similar?
Alex
