Results 1 to 3 of 3
Thread: 2kSilverado, Getting started, Need resources.
    Senior Member acomp917's Avatar
    Jan 2010
    Default 2kSilverado, Getting started, Need resources.
    Third post, NEW here.
    I have done quite a lot of aftermarket real-time tuning. All closed systems, except Megasquirt.
    I'm planning on learning EFI live by logging/tuning my stock daily driver(GASP!). It is a 2000 silverado w/ 5.3l,
    Basic ideas below, are they sound?:
    1- I think that makes it a LM-7... ?
    2- I plan to go the MAF only, adjust the IFR, then go map only, auto VE, then connect both again and run closed loop(seems like the simple direct route).
    3- Will perfect that tuned stock system for a while(also my methods).
    Bigger Problem I would then like to flash a COS(learning and getting ready to turbo/LSx my old "97" fbody). My problem is that I haven't found ANY resources that will cross year/model PCM numbers and then cross to COS's. I have read a LOT and can't figure out what years/models/PCM#'s/internal flash #(whatever it's called)/memory amount/ and generation are used for custom applications. I basically only know about the (E40) and (e38) reluctors and other electrical requirements(schematic stuff).
    Can anyone run a sanity check on my ideas? and/or Provide me with a source for the cross reference that I need(like the OLD!!! ludis pages).
    Thanks in advance for any help,
    S
    Jan 2010
    OK, I'll just post to myself.
    Here's what I am going to try to do. I was just taught (thank you Mr.Prick) about how to disable 2nd o2's, EGR, and AIR and how to use a script to do that. I believe that is the very beginning. I'm going to keep track of ALL of the PDF's, scripts, suggestions, and everything else in different directories. As I proceed, I will categorize it all with the gained knowledge.
    If I ever put it all together, I will try to make a TRUE beginners guide. Finding, realizing the relevance of, and remembering what a beginner reads in these forms is nearly impossible(I'm not really a beginner).
    Any and ALL help will be appreciated.
    S
    Jan 2010
    I found a good source of information on PCM service numbers based on year
  1. Need help getting started.
    By blownss06 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 3rd, 2010, 06:14 PM
  2. is this all I need to get started?
    By printmanjackson in forum Purchase and Shipping
    Last Post: November 18th, 2009, 07:10 PM
  3. getting started with V2
    By beaukz28 in forum Purchase and Shipping
    Last Post: October 15th, 2008, 01:31 AM
