Page 17 of 20 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 199
Thread: New Tuning Tutorial: WeathermanShawn
  1. #161
    Quote Originally Posted by Ninety8C5 View Post
    Where did you find that ? I just checked OS 19980400 (that's the one I asked for) and a quick check of OS 19980200 and they are both X out as not valid. Is there something else I need to look at? Do I need to re-validate PIDs?
    Thanks.
    I see you have already found this: showthread.php?t=13320
    Hmmm... I though I had seen an update for 19980200......I don't know now what I had been looking at (sorry).
    Do what mr.prick said, Validate Pids.
  2. #162
    Ok, I'm confused... I pm'd Tech Support regarding the 19980x00 os's support of these pids:
    GM.CYLAIR_DMA
    GM.DYNCYLAIR_DMA
    GM.DYNAIRTMP_DMA
    If DYNAIRTMP_DMA isn't supported, then the lookup of B4901 would be the way to go.
  3. #163
    Apr 2007
    GM.CYLAIR_DMA
    GM.DYNCYLAIR_DMA
    GM.DYNAIRTMP_DMA
    Joecar - Any updates on this?
    BTW - Both GM.CYLAIR_DMA and GM.DYNCYLAIR_DMA work fine for me, it's just the GM.DYNAIRTMP_DMA that doesn't work.
  4. #164
    Ok, I'm told that those do not exist for the 1998 OS's... sorry.
    So the next best thing is to use the lookup(B4901) method, see Ninety8C5's link in my post above (post #162).
  5. #165
    Sep 2003
    It was late last night when I typed that... <- me slapping upside my head 4x
    Sorry, I had meant to type this: 0.85*IAT+0.15*ECT
    i.e. it should biased toward IAT.
    I intended that as a simple estimation, exactly what Shawn guessed I was doing...
    I say this from looking at B4901 and from observing DYNAIRTMP_DMA say when VSS > 30 mph in various logs...
    I should have instead said to study B4901 for your airflow range, which brings us to the next point:
    A more accurate way to do this is to do a lookup of the B4901 values as suggested by mr.prick earlier in this thread...
    and this is exactly what Ninety8C5 did: showpost.php?p=118165&postcount=29
    [ but this still doesn't factor in B4902 ]
    The 1998 OS's don't have B4902.
  6. #166
    That's one less thing to worry about...
    I think the lookup of B4901 will work pretty good (GM did spend many man-hours on this).
  7. #167
    Default For anyone who found this thread...
    Here is the current calc_pids.txt file for the tutorial (works for VE[%] and VE[g*K/kPa]).
    The pdf is included in the latest install of V7.5.
  8. #168
    May 2007
    cheers Joe! I saw that thread the other day but didnt think it applicable due to e38 but if it does the MAF its worth a shot
    PS do you not know where anythings located
  9. #169
    There's so much stuff that I keep forgetting where it all is...
  10. #170
    Jul 2005
    Why?
  1. How about a transmission tuning tutorial!
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 3rd, 2020, 04:53 AM
  2. Tuning Notes by WeathermanShawn
    Last Post: July 12th, 2013, 03:21 AM
  3. WeatherManShawn's Tutorial: can someone look/help...??
    By tatasta in forum Gen III V8 Specific
    Last Post: April 28th, 2010, 02:25 PM
  4. Idle tuning... more info on tutorial please!
    By vxleather in forum Tutorials
    Last Post: July 16th, 2008, 12:11 PM
  5. How about a transmission tuning tutorial!
    Last Post: August 5th, 2006, 04:09 AM
