Results 11 to 20 of 26
Thread: Return to Closed Loop?
    BTW(unrelated): set B3609 to all zeros.
    How much was the initial bump up of the VE table...?
    This is an LT1...? How big is the motor and cam...? What other mods...?
    Oct 2006
    There is a bit of a trap involved in just raising the whole table in some OS's.(like this one appears to be). Since over 4000RPM is usually uncalibrated due to the maf taking over at this point. The 4000 RPM band gets jacked up during AutoVE due to interpolation with the lower 4400 RPM band.
    The Tremor at AIR
    Apr 2009
    I started with a 15% increase of the VE and went from there.
    Mods include:
    Hotcam - 218/228, 525/525, 112 .....unsure about rocker ratio
    Mildly home ported stock heads
    Longtubes
    Moroso/K&N CAI ?
    Edelbrock TB
    No cats into a bullet style muffler
    Those are the highlights. It makes decent torque. I rather like it.
    Yes. It's a stock bottom end LT1
    Last edited by DPS; May 5th, 2010 at 02:36 PM. Reason: I don't know how to press buttons
    Apr 2009
    Quote Originally Posted by 5.7ute View Post
    Is hand smoothing the 80kPa and below values to trend more like the 85kPa and up values beyond 4000rpm the proper way to fix this?
    Thanks for the tips guys!
    -Brad
    Oct 2006
    Quote Originally Posted by DPS View Post
    -Brad
    Pretty much. Your 4000 RPM values appear to be jacked up due to the low 4400 RPM row. But this will clean itself up once you do another tuning run.
    Another tip is to try & hit the centre of the cells, especially with the rpm bands. For instance I will set cruise control to 2000 RPM & use the terrain to vary the map cells to do this band on road. Not as good as a dyno, but it gets you there fairly quickly.
    The Tremor at AIR
    Brad, can you post some very recent log files...
    Apr 2009
    Here is a log file based on the 0015.tun that I posted previously.
    I've also attached 0016.tun that has the changes implemented that were suggested by you guys.
    Please take a look and tell me if it's worth flashing 0016.tun to the car before it leaves. I will not get a chance to log or re-tune anything before it goes.
    Thanks again guys!
    -Brad
    Jul 2008
    Something still looks amiss..at least on my Scan Tool.
    I see you want it to go to closed-loop, but your Scan says it stays open-loop the whole time? Also, it looks like one or both your O2 sensors are not working. H02S11 stays flat-lined. Furthermore there are no LTFT or STFT's..
    But I see in your tune you have those enabled.
    So, it still looks like SD-Open Loop..I am confused also...
  9. #19
    Apr 2009
    What you just described has been the problem right along. I wanted to put it into CL but for some reason it wouldn't switch over. Perhaps it is the O2 issue that you discovered.
    I was going to give the car a final flash tonight before it leaves in the morning as a last ditch effort to put it into CL. Since I have little confidence that it will work, I've been massaging the VE Table (97 Z28 0016.tun) per 5.7Ute's advice. That way if it stays in OL I will have a little more confidence in it.
    -Brad
  10. #20
    Nov 2006
    Clear the DTCs you have and try again.
    LC-1 WBO2
  1. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 03:37 AM
  2. Not going into closed loop
    By tblu92 in forum Gen III V8 Specific
    Last Post: February 12th, 2008, 10:22 AM
  3. closed loop and open loop switching
    Last Post: July 10th, 2006, 08:56 PM
  4. Finished 3 bar SD TUNE. How do I return to closed loop?
    Last Post: October 13th, 2005, 04:56 PM
  5. Open Loop SD VS Closed Loop SD Advantages???
    Last Post: August 4th, 2005, 12:25 PM
