Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 61
Thread: Connecting LC1 to V2
  1. #41
    I circled the terminator plug in red in the attached image.
    Edit: Joe, your picture is much better
  2. #42
    lol... I think I overdid my pic...
  3. #43
    Nov 2005
    I love you guys
    I can't believe that this little dead end plug is whats needed to make this work. It doesnt make sense to me, but what do i know. As soon as i plugged it, the 2nd from left orange light started blinking every second.
    It is working at laaaaaaaaaaaaaaaast. I drove around and the AF was perfect showing mid 12's under WOT.
    Thanks a bunch for all the help. Really appreciate it.
  4. #44
    Jul 2010
    Is this wiring right or wrong if it wrong so can you show a correct one
  5. #45
    Nov 2006
    Is that a null modem or a gender bender?
    A null modem is needed.
    LC-1 WBO2
  6. #46
    Quote Originally Posted by LSs1Power View Post
    I love you guys
    That little plug is detected by the LC1. As soon as it detects the plug it starts transmitting the serial wide band data. If it does not see the plug then it does not transmit the data.
    I'm pretty sure it has something to do with the LC1's ability to be daisy chained with other LC1's. Each LC1 in the chain waits for the previous LC1 to transmit its data, then it appends its own data to all the previous LC1s' data.
    So basically the furthest away LC1 needs to be "told" not to wait for any other previous LC1's data (since there is no further LC1 in the chain) and to just transmit its data, to which all the other LC1's will append their data as the data makes it way back to FlashScan along the chain.
    If you only have 1 LC1, it doesn't know its the only one and therefor the furthest one and that it should just transmit its data and not wait for another (further away) LC1 to start transmitting. The only way to "tell" it that information is to plug the loop back dongle into its serial cable.
    That's my understanding it could be wrong, the guys at Innovate would know more...
  7. #47
    Nov 2005
    My A/F is reading 5 AF which is not right. The Lambda is reading 1.0 around idle like before when it was reading 14.5-14.7 AF.
    I re-calibrated the sensor and it is still showing 5 AF. Is there a way to diagnose the problem? I mean how can i know if the problem is the Oxygen Sensor itself or a calibration problem?
  8. #48
    Did you install the latest software/firmware from here.
    V8 build 106 includes firmware 2.6.36, you have to flash this into V2.
  9. #49
    Nov 2005
    Yes, nothing changed from before. Everything was working fine and reading as the Dynojet AF gauge. All of the sudden it started reading off. I'm not sure if it is the Oxygen sensor being off or something else.
    Is there a direct relationship between the Lambda reading and the AF? Can you convert the Lambda reading to AF mathematically?
    I'm asking because the Lambda reading did not change while the AF number changed. I'm trying to diagnose the cause of the problem.
  10. #50
    Direct relationships: AFR = STOICH_AFR * Lambda and EQR = 1 / Lambda
    So with your LC-1 you're seeing V2 say Lambda = 1.00 and AFR = 5...?
    Can you check this: with LM Programmer software check what STOICH AFR the LC-1 is programmed for.
    Can you post a log file showing WO2AFR1, WO2LAM1, WO2EQR1, WO2ST1.
  1. RR not connecting..need help
    By superspeed in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 29th, 2009, 12:50 PM
  2. Connecting LC-1's
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2009, 10:21 AM
  3. New help connecting to RR
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2007, 11:57 AM
  4. connecting lc1 to v2
    By mr.prick in forum FlashScan V2
    Last Post: February 8th, 2007, 01:46 PM
  5. LM-1 connecting to V1
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2007, 11:06 AM
