Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 61
Thread: Connecting LC1 to V2
  1. #51
    Nov 2005
    Attached you will find the log file.
    I will have to make another log to capture all the variables you wanted below.
    My LMprogrammer doesn't work. I have never accessed the LM Software before. It was working before so I'm assuming nothing has changed there.
  2. #52
    Have you tried re-installing LM Programmer...?
    Sometimes the LC-1's value for STOICH AFR changes by itself, a few of us have seen this.
  3. #53
    Yes, do get another log that also includes WO2EQR1 for sanity check.
  4. #54
    Nov 2005
    I will try to access the LM Programmer again.
    Which end should I connect the laptop to, IN or OUT to read from the LC1 Module Right through the serial connection?
  5. #55
    Default LM Programmer connection
    SERIAL IN <-- 2.5mm blank stereo plug (leave this permanently connected)
    SERIAL OUT --> LC-1 serial cable --> PC/laptop (i.e. remove the null-modem adapter)
  6. #56
    Nov 2005
    It took me a while to find an adapter to to convert Serial to USB.
    Here is the screen shots
ID:	8726   Click image for larger version.
ID:	8727   Click image for larger version.
  7. #57
    Nov 2005
    I changed the first page setting to Gasoline and it worked just fine.
    I guess LC1 setting did change by itself.
    Thank you
  8. #58
    Yes, keep an eye on it, this is an LC-1 quirk.
  9. #59
    Set the LC-1 stoichiometric AFR to the same value as your B3601.
  10. #60
    Nov 2005
    What do you mean? Where can i find b3601?
  1. RR not connecting..need help
    By superspeed in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 29th, 2009, 12:50 PM
  2. Connecting LC-1's
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2009, 10:21 AM
  3. New help connecting to RR
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2007, 11:57 AM
  4. connecting lc1 to v2
    By mr.prick in forum FlashScan V2
    Last Post: February 8th, 2007, 01:46 PM
  5. LM-1 connecting to V1
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2007, 11:06 AM
