Page 8 of 8 FirstFirst ... 678
Results 71 to 78 of 78
Thread: Wiring L92 with O2 sensors
  1. #71
    If the engine is a stock LS3, then yes load the stock LS3 tune.
  2. #72
    Is 12591290 a 2-bar or 3-bar sensor...?
    If that is the same MAP sensor on the LS9, then the LS9 tune file has B2101 set to 312.5... i.e. it looks like 3-bar to me.
  3. #73
    Lifetime Member 68problemchild's Avatar
    Mar 2010
    Reinstalled LC-1. It has a flashing light (two short flashes, pause, two short flashes, pause, .....) and shows error "2" when turned on.
  4. #74
    Shows 2 flashes of the LED, and shows "2" on the V2 LCD...?
    LC-1 User Manual says:
    Error 2 = sensor heater circuit is open (i.e. the heater circuit between the LC-1 controller and the actual sensor);
    unplug the sensor from the controller and carefully re-plug it together.
  5. #75
    Mar 2010
    Tried that and switched the neg and pos power wires. Played with the V2 and got it to read Error 1 versus Error 2. Slow single flash versus slow double flash. Read the manual and replugged it but I think its time for a new unit.
    Its going back. Anyone got a recomendation on another O2 sensor ?
  6. #76
    Mar 2010
    Okay, got this refurbed and returned from Innovate. I will give them one more try.
  7. #77
    Double check your wiring before applying power.
  8. #78
    Mar 2010
    OK, exact same double flashing light as before. Sensor does not heat up. I assume the engine does not have to be running for power. NB sensor reads fine from same plug.
    Next sensor you would recommend that can be read/be recorded by V2 / EFI live?
    Anyone want to buy an Innovate?
    Thanks guys.
  1. LS3 L92 newbie
    By 68problemchild in forum Gen IV V8 Specific
    Last Post: May 3rd, 2010, 12:02 PM
  2. L92/L76 AFM/FlexFuel
    By Cougar281 in forum Gen IV V8 Specific
    Last Post: April 21st, 2009, 10:38 AM
  3. what ecm for a 07 L92 6.2L
    By nycblazer in forum Gen IV V8 Specific
    Last Post: February 15th, 2008, 04:18 PM
  4. Need help - L92 and 6L80E going into a 66 GTO...
    By Newguy in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2008, 11:08 AM
  5. L92 Data log
    By etmotorsports in forum Gen IV V8 Specific
    Last Post: January 26th, 2008, 05:04 PM
