Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: acetone improve fuel economy?
  1. #21
    Aug 2009
    Quote Originally Posted by blindawg View Post
    are you saying that using E85 in my 2000 S10 that isnt designed for it will hurt it?
    ive always wondered. never tried because i didnt want to find out the hard way.
    Thanks,
    Branden
    How are you going to run it, if it isn't a flex fuel motor, since it will not know to increase the fuel flow? Is your S10 a 2.2 or a 4.3? If its a 2.2, I thought all 2000 and newer ones were flex fuel
  2. #22
    Lifetime Member blindawg's Avatar
    Sep 2010
    and i wasnt sure what was all done when E85 was used. thats why i never tried it and asked. lol
    so trying it would not be a good idea?
  3. #23
    Aug 2009
    4.3
    I don't think the injectors in the 4.3's can flow enough fuel to safely run E85
  4. #24
    Sep 2010
    ok. ill take your word for it.
    im going to be putting a 5.3 in it sometime in the future, will E85 work with that?
  5. #25
    You have to edit the stoich AFR and maybe the OLFA/PE tables... you will find that the injectors then need to flow more, so they may have to be upgraded.
  6. #26
    Aug 2009
    What year 5.3 are you planning on putting in it? The Gen3 5.3's can be made to run on E85 with the right tune, I'm pretty sure some of the later one came already set yp for it
  7. #27
    Sep 2010
    thanks Joecar.
    We dont know on the year, it'll be from the salvage yard. any certain ones to look for?
    Thanks,
    Branden
  1. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  2. E38 Crank Fuel to Run Fuel Transition
    By Wazzup13 in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2009, 11:12 AM
  3. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 06:15 AM
  4. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  5. part throttle fuel tbls and WOT fuel tbls
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2006, 06:49 PM
