Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 95 chevy truck .xml
    Dec 2010
    Default 95 chevy
    Thanks for the info Blacky I am working on the definitions now it would help if I new one of the current definitions that is correct to use as a template or comparison. You made it sound so easy just type everything in, wish that were true, lol. Any other insight on this attempt would be appreciated, Thanks in advance
    Check out the *.xml files called gmXXX.xml, they should match up with the aXXX.ds files that have the same number.
    i.e. gm274.xml is based on A274.ds
  1. Swapping 12200411 PCM into 98 Chevy Truck
    By 350SS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2017, 01:05 AM
  2. Crank sensor relearn 97 chevy truck
    By Gregs in forum General
    Last Post: March 29th, 2010, 02:21 AM
  3. Need some help from a Chevy Truck Mechanic
    By BRD-PREY in forum Duramax LB7
    Last Post: March 2nd, 2009, 12:42 PM
  4. 90 chevy truck with ls1 t56 transplant tuning help
    By bigblaze in forum Gen III V8 Specific
    Last Post: November 8th, 2007, 04:23 AM
  5. 2002 chevy truck, TM tune
    By ytry in forum General (Petrol, Gas, Ethanol)
    Last Post: May 15th, 2006, 07:13 PM
Tags for this Thread
