Page 6 of 75 FirstFirst ... 456781656 ... LastLast
Results 51 to 60 of 741
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #51
    And thanks to Blacky who promptly fixed the order-of-evaluation-bug that was delaying calculated pids by a few frames.
  2. #52
    Jul 2008
    Thanks Blacky. You made it work!
    Joe, double-check the calc_pids.txt file now on post 1. I think I have the right one now..
  3. #53
    I checked the calc_pids.txt in post #1, it is now the right one
  4. #54
    Quote Originally Posted by Frozen WS6 View Post
    But I see no way to add new pids anywhere, or find any how to, to tell me how or where to do it.
    Hi Frozen,
    The new pids are added via the calc_pids.txt file...
    If you have not previously edited your calc_pids.txt file, then copy the calc_pids.txt from post #1 to this folder on your PC:
    My Documents\EFILive\V7.5\User Configuration
    that's for WinXP; Win7 is slightly different (but similar).
    Make sure you have V7 software build 149 as this has a calc pid bug fix.
  5. #55
    Sep 2008
    Hi Frozen,
    Thanks. I'm printing it out and working on that right now. I just went in and made sure I'm all up to date and no new updates so I should be good there.
    Another question. I see I need to select the VSS pid. How important is that?
    My car has a turbo 350 so that speed sensor is gone and my wheel speed sensors are gone also because of the addition of lightweight brakes, abs delete, and ford 9 rear.
    I think this looks right.
    # Add slot definitions here
    *CLC-00-020
    factor 0 1 .0 "{GM.EQIVRATIO} > 1 && {SAE.RPM} > 1200"
    *CLC-00-110
    factor 0.5 1.5 .4 "{GM.EQIVRATIO} * ({CALC.AFR_LC11}/14.7)"
    *CLC-00-200
    factor 0.5 1.5 .4 "({SAE.LONGFT1}+{SAE.LONGFT2})/200+1"
    *CLC-00-220
    factor 0.5 1.5 .4 "iff({CALC.PE}, {CALC.WO2BEN1}, {CALC.LTFTBEN})"
    *CLC-00-300
    % 0.0 100.0 .2 "{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C}+273.15)*3445. 2/(5.669*{SAE.RPM}*{SAE.MAP.kPa})*{CALC.SELBEN}"
    VE 0.0 2.468 .4 "{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C}+273.15)*1 5/({SAE.RPM}*{SAE.MAP.kPa})*{CALC.SELBEN}"
    CALC.PE F020 CLC-00-020 factor Enrichment "PE Mode"
    CALC.WO2BEN1 F110 CLC-00-110 factor Wideband "BEN from Serial Wideband 1"
    CALC.LTFTBEN F200 CLC-00-200 factor Tuning "BEN from LTFT"
    CALC.SELBEN F220 CLC-00-220 factor Tuning "BEN selected from LTFT or WB"
    CALC.VET F300 CLC-00-300 "%,VE" Tuning "Calculated VE Table"
  6. #56
    Jul 2008
    You don't really need VSS.
    I think everything else looks O.K. with the Calc. Pids. Make sure you log everything that is in that formula, including DYNAIRTMP.DMA.
    You can always post your selected Pids if you have any questions..
  7. #57
    Sep 2008
    Ok so after reinstalling the 7.5.149 update. I still only have these pids and a couple that are red x'ed that look like I'm not able to use.
    I'm still missing BEN from LTFT
    Calc VE Table
    PE Mode
  8. #58
    Jul 2008
    Frozen, if you look under the PID file name you will see a Tab that currently you have selected 'ALL'.
    I don't see any of your Calculated Pids selected..so with that same TAB, check under the following:
    1. Calculated
    2. Tuning
    3. Enrichment
    4. Wideband
    Try that. See in your calculated pids that where you have them directed.
    The only PID that I am not sure your OS has is DYNAIRTMP.DMA. If you try the above again, let me know if DYNAIRTMP.DMA still shows invalid. There is a work around this one, but I need to know first..
    Also, sometimes PIDS won't show up the first time unless you have the Scan Tool hooked up to the car. In fact there is a TAB called 'Validate Pids", You may have already done that, so feel free to ignore if you have already done that.
  9. #59
    You can click on the column heading "Caption", click on it one more time, the pid list now appears sorted alphabetical order on this column.
    Or do what Shawn said.
    Also, this is not important, if you care about the description, change Serial to Analog:
  10. #60
    Jul 2008
    Just an Added Note:
    For those OS's that do not have the DYNAIRTMP.DMA Pid supported, Forum member Ninety8C5 developed an excellent Calculated Pid that is highly accurate substitute.
    This Table needs to be specific to your OS (if DYNAIRTMP.DMA) is not available. I.E. The Values need to match the Charge Temperature Blending (Factor) in B4901. Of course you would just simply substitute that Calculated Pid into the CALC.VET Equation.
    EDIT: See Page 1 for all current CALC.Pids..
    Last edited by WeathermanShawn; February 19th, 2011 at 12:09 AM. Reason: Updated Attachment..
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
