Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 156
Thread: How about a transmission tuning tutorial!
  1. #111
    I don't have any 6L80/90 to experiment with or otherwise destroy...
    These work different than the 4L60E/4L80E in that the components are sequenced electronically rather than hydraulically, and the trans calibration contains timing relationships which are critical.
    Some people have figured out how to tune these.
  2. #112
    Mar 2005
    Quote Originally Posted by BowlingSS View Post
    I would love to see a 2011 Camaro Trans tune write up.
    Bill
    Anyone here that would be willing and able to write-up the basics of the do's and don't's of how to tune the 6 speed auto T43?
    Ron
    2014 Silverado 4X4 6.2L
    2010 Camaro 2SS-RS L99
    2007 Sierra Denali 6.2L
    2005 1500HD 4X4 Quadrasteer 6.0L, COS3 SD
  3. #113
    May 2009
    Hi All
    I have been searching for the trans tune pdf and am only able find this one by ringram in April of 06. Is this the most recent?
    Quote Originally Posted by ringram View Post
    Ok, so I forgot you can attach files to posts now..
    Anyway here is the magic document with most of the info from this thread.
    Ill add in Joecar's shift pressure pics and update the doco in the next few days. In the meantime, go and break traction with this doc.
    The link in the Thread: Collecting links to scattered tutorial material... doesn't seem to function.
  4. #114
    Aug 2010
    Try the link below ...
    http://forum.efilive.com/showthread....l=1#post131266
    Regards,
    Taz
  5. #115
    May 2009
    Hi Taz
    Thanks. The post you reference is how I landed in this thread. In the thread you are referencing post 3 has a link to a trans PDF and there are links to it in this thread. Only enquiring to see if there is an update since the one attached in 2006.
    Great work all!
  6. #116
    Senior Member johnmaster's Avatar
    May 2011
    Hello again, been 6 mos since I plugged my scanner into the truck, getting back into it to figure out if I can get this trans to shift more crisp. At least I can learn on this one and if I blow it up its no big deal...99 silverado 2wd 4l60 with a skillion miles on it, turboed now and wondering how much I can pour to this poor thing before the trans gives up. Took a drive and logged before making the pressure and shift time changes mentioned in this thread, part throttle shifts are much more crisp now. Bad news is my 1-2 shift takes about 1.3 seconds measured from peak to valley of my rpm curve WOT. 90 psi pres control solenoid pressure while it is shifting which I believe is maxxed. shift times are at .25 seconds on the tune and tm is zeroed.
    How do I tell it's slipping and can't be tuned into shape? Should I try it with 0 in the appropriate cells for d1108 and see if it helps any? I get the feeling I am going to be shopping for a real solution...
    Thank you to all who have contributed so far!
  7. #117
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Wished someone would do a 6L80 tuning tutorial.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
  8. #118
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    that would be nice
  9. #119
    Aug 2009
    Bill
    The issue with T43 is that every one of them behaves differently!
    I could do a tutorial of what i have found so far ,but it would really be useless IMHO. You flash your first T43 and drive the car and you'd think "oh wow, that's great" . Put the same numbers in the next car and it behaves totally differently.
    6L80E & T43 is a tuner's nightmare
  10. #120
    Dec 2010
    Back from the past... Found this thread accidentally in search... how come it never made a sticky or link or? Lots of good ideas!
  1. New Tuning Tutorial: WeathermanShawn
    By WeathermanShawn in forum Tutorials
    Last Post: March 1st, 2011, 09:31 AM
  2. Question on Tuning with AutoVE tutorial
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 1st, 2009, 03:35 AM
  3. How about a transmission tuning tutorial!
    Last Post: August 5th, 2006, 04:09 AM
  4. Simple yes or no...would you like a tuning tutorial for EFI Live?
    Last Post: July 22nd, 2006, 02:38 AM
  5. Tutorial for tuning VE using LTFT's using EFILive ??
    By Thedude in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2005, 10:55 AM
