Page 3 of 16 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 154
Thread: Improving shifts via the ECM
  1. #21
    Lifetime Member Rhino79's Avatar
    Jul 2006
    Thanks so much ross. And for what its worth, the torque tables work great on e38/t42 combos as well!!!
  2. #22
    Apr 2010
    TCC slip tables were added in the latest release
    I'm really happy to read that everyone has had great improvement with the torque tables.
    Which version of the software is this? I can't find it anywhere in RC10 - is there a newer ver now?
  3. #23
    Apr 2010
    Quote Originally Posted by DeadRinger View Post
    Oh nevermind - I see that RC10 was replaced by a public release I missed... going to upgrade now!
  4. #24
    Quote Originally Posted by Rhino79 View Post
    Interesting...going to have to play with that on my E67/T42 TBSS soon then! Working on a few other tricks for it now (running a car TCM OS so the TCC doesnt unlock when letting off the gas, simply using the car OS instead of the stock one netted me a +1mpg on a 650mi round trip) and just got my efans installed.
    Should I try blanket adding like +10% to the torque tables and seeing how the trans shifts?
  5. #25
    Yes, just do the ones mentioned in the thread (there is lots of them), see how it feels at 10%.
  6. #26
    Cool, Ill start there. Gotta get a few other things done first then try this, cant try too many things at once or I have no idea what actually helped!
  7. #27
    so has anyone else played around with b3001 - b3003 yet?
    I have increased mine but I havent done any wot runs, just along with the existing 15% increase in the other torque model table shifts are pretty firm at mid to high throttle. which is what i expected having only adjusted the 40-100% table.
    Absolute Difference
Name:	EFILive Tune V7.5 - LS3-HTV2300-60psi-fuel pressure_0035.png
    New Configuration
Name:	EFILive Tune V7.5 - LS3-HTV2300-60psi-fuel pressure_0035-2.png
    Original Configuration
Name:	EFILive Tune V7.5 - LS3-HTV2300-60psi-fuel pressure_0035-3.png
  8. #28
    Jul 2005
    You are assuming I know it
    If you send me some raw data, i could probably figure it out.
  9. #29
    These will make a difference, but, a much smaller one. In early testing these were the only tables we had put in. Putting the values from a LS7 in to a L98 made a difference, just not enough. But it certainly wouldn't hurt to change them.
    Quote Originally Posted by redhardsupra View Post
    The thing is, to get the desired results there is really only one table that needs to be changed, changing it (at least on a non VVT engine) is very simple and doesn't need to be scientific, plus you can log a PID that shows the torque value so you know how much things changed. I look at it from this approach, you stick a BluRay disc in the player and press play, do you have to know the technical details behind how the picture gets to the screen or do you just sit back and enjoy the movie for what it is.
    There is no more 'raw' data than what you see on the screen.
  10. #30
    Jul 2005
    I'd prefer to know how the torque estimation happens, or at least what variables are involved.
  1. How mcuh should be A/F between shifts ?
    By wesam in forum Gen III V8 Specific
    Last Post: September 20th, 2010, 07:14 AM
  2. spikes during shifts??
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: January 9th, 2009, 05:02 PM
  3. Shifts to soft from 1>2... HELP!
    By LS1FREEK in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 26th, 2008, 12:10 PM
  4. ETC help on shifts please.
    By azzhauler in forum General (Petrol, Gas, Ethanol)
    Last Post: November 8th, 2006, 11:20 AM
  5. Replies: 0
    Last Post: February 6th, 2006, 10:12 AM
