Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 53
Thread: Evaporative purge system not ready
  1. #31
    Member way2much_01's Avatar
    Sep 2007
    Im having the same problem 1 monitor is showing not ready it passed everything but the stupid check engine light. How do I find out what monitor is incomplete? And will this help me get pass my inspection? Oh by the way it's an 02 Sierra
    BlackBear, HSW N20 100 shot
  2. #32
    Sep 2007
    Quote Originally Posted by [email protected] View Post
    Joecar will probably provide the best answer. Does your scan tool say that you have a check engine light, or do you have a check engine light on? In the scan program, when you connect to the computer the first thing that runs is the status of the DTC's. Click on SRT tab aand it will tell you which monitor has not been set to ready. It will also tell yo if you have a MIL light or code set. If there is a code set, look on the V2 without the V2 connected connected to the computer and it will tell you what code has been set. Just remember, if you clear the code with the scanner (V2), or change the program with the tune software, all of the readiness status indicators will again say not ready.
    No cel but it's showing C0265 under srt, it's showing heated catalyst and egr system not supported in the srt tab so that means not ready right?
  3. #33
    Sep 2007
    My system showed a red x in front of the srt systems that were not ready. The systems that are not supported show not supported. I am resonably sure that your vehicle does not have a heated catalyst or egr system. I am wondering if you might have used the off road tune from above for the 2007 Z06 or the off road tune for the 2002 vette that were previously shown and might have used the wrong dtc's for your vehicle. Best wait on joecar if any of the above applies.
    Nope didn't touch anything in the tune
  4. #34
    In scantool, goto the OBD II tab, goto the SRT subtab, and there you will see all 11 monitors...
    Not Supported = monitors not supported by the PCM (i.e. PCM's vehicle came without that equipment);
    Not Ready = monitors that have not yet run;
    Ready = monitors that have run (they may have passed or failed);
    each monitor requires a set of DTC's to be tested for, those DTC's are listed in the Service Manual and are specific to year/model/vehicle.
  5. #35
    Quote Originally Posted by way2much_01 View Post
    C0265 would be shown under the DTC subtab...
    C0265 is a Chassis/BCM code... that should not prevent you from passing the emissions test.
    If your vehicle is prior to 2000, then you are allowed to have upto two Not-Ready monitors; if 2000 or later then only one is allowed.
    Not-Supported monitors are not tested because the vehicle does not have the emissions equipment for those monitors.
  6. #36
    Is the Check Engine Light on...?
    Or is the Service Vehicle light on (C0265)...?
    There is a big difference and the smog technician should know the difference.
    For example, sometimes if you forget to turn off traction control on a Camaro/Firebird/Corvette, during the roller test the ABS will throw some DTC's (because the front wheels are stationary and the rear wheels are driving at 30 mph...) this causes the SVS light to turn on... if the tech mentions this just remind him that it is the ABS and not the engine that threw the DTC (Service Vehicle vs Check Engine).
  7. #37
    Does your truck have Heated Catalyst and EGR...?
  8. #38
    Sep 2007
    So am I to set them to not reported as post #9? For off road use?
  9. #39
    Sep 2007
    I'm not sure Im in California so I should right?
  10. #40
    Sep 2007
    No check engine light but it shows up under dtc's in the scan tool
  1. 98-99 pcm swap ? 69 brown evap purge
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: January 9th, 2008, 04:51 AM
  2. LTFT under high manifold vacuum & EVAP Purge
    By vettenuts in forum General (Petrol, Gas, Ethanol)
    Last Post: July 25th, 2006, 10:10 PM
