Results 1 to 10 of 12
Thread: Timing control functions
    Redline Motorsports
    Guest
    Default Timing control functions
    I have a few questions regarding the timing control that we have with tuning software. If for example I put all 25's in the entire base timing map (for both high and low octance), zero out the timing tables for {5910} spark ECT table and {5911} spark IAT table shouldn't I get 25 degrees of timing? Are there any other tables that will affect overall timing?
    The other question; with some of the bi-directional controls can we control timing in real time for a short duration?? We have an eddy current load dyno and it would be real cool to be able to load the motor and play with timing on the spot.
    Howard
    There is more timing tables than those you listed....feel free to explore
    Also, depends on the year, earlier O.S's (2000 etc) had less than a 2006 vehicle. Torque reduction can cause weird numbers.
    Also, don't forget about the spark DMA PID's.
    Yes you can overide timing in the bi-directional control panel.
    You can fix the timing at a given number or add/subtract timing from the final run spark value, good for doing what you want to do, just throw a few degrees at it without relfashing whilst on the dyno.
    I know another method that will work great on the dyno, but I can't say too much yet
    Redline Motorsports
    Guest
    I know that TM can effect overall timing values while driving but what about when the car is on the dyno with the traction control off (C5)?
    Where in FS can you do that with the timing??
    Top secret! How much longer?? Its bad enough we have been waiting patiently for V2 this long! LOL!!!
    Lifetime Member johnsZ06's Avatar
    Sep 2003
    I've noticed the same thing. I will play back a log file in the scan tool and try to follow the timing inside the tune tool (a neat feature BTW). I will sometimes lose up to 8 degrees of timing that I can't account for. I know things like IAT and engine temp will pull timing but more often than not, these tables are at "0". There must be something else behind the scenes that we can't see.
    Log all the pids that begin with EST_
    Redline Motorsports
    Guest
    Good point. By logging all of those pids the culprit will show its head!
    Jan 2005
    Feb 2005
    log the "run spark" pid to see what final spark is.
    99 FRC 402 Twin Turbo
    Sep 2003
    Also check table B5919 and make sure the values are high enough
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Quote Originally Posted by TAQuickness
    But for some strange reason....I think I have an idea. Could be wrong.
  1. lower/eliminate TC functions.
    By acomp917 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 23rd, 2010, 09:28 AM
  2. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    Last Post: November 17th, 2009, 01:15 AM
  3. LS7 E67 fan control
    By rally1 in forum Gen IV V8 Specific
    Last Post: December 18th, 2008, 06:38 PM
  4. Custom PID: What functions can you use?
    By 2002_z28_six_speed in forum General
    Last Post: September 3rd, 2007, 06:05 PM
