Page 19 of 21 FirstFirst ... 91718192021 LastLast
Results 181 to 190 of 202
Thread: options request : post your ideas
  1. #181
    Nov 2006
    This will get you what you want until then.
    LC-1 WBO2
  2. #182
    Lifetime Member Rich Z's Avatar
    Well then, in that context, thank you for your help.
    CorvetteFlorida.com
    2002 Corvette Z06
    427 RHS block built by LME
    STS rear mounted twin turbos
    It nearly died on the operating table, but I'm bringing her back.
  3. #183
    Hi Rich,
    Most of us manually move the chart inspector/cursor back/forth thru the chart when analyzing a log...
    if you wanted to to play segments of the log, then you could crop each segment and save to a new file (one segment at a time), this would then let you integrate with your video(s).
  4. #184
    Hi Rich,
    Yes, I have been doing that as well, but when scanning through a LONG log file just looking for anything that looks *different*, it's quite tedious that way. Maybe when I am more familiar with this stuff I won't feel like I need to look at EVERYTHING, or will know exactly where I need to look for something. But right now, I just don't know what is "normal" and what is not. So I am presuming the longer I look at log files, eventually SOME of the stuff will have to be considered as normal, and the stuff that is not normal will become more apparent to me.
    CorvetteFlorida.com
    2002 Corvette Z06
  5. #185
    Ooh, I've got another one....
    I'm looking at a log file, and want to look at ONLY the relationship between two of the values being tracked. Sure would be nice to have a way to QUICKLY hide the tracks I don't want to see at the moment. Something like right clicking on the trace or the label and just being able to select "hide" and then being able to make it visible again as needed. Kind of like when looking at multiple parallel audio clips you can mute any track separately.
    Just a thought....
    CorvetteFlorida.com
    2002 Corvette Z06
  6. #186
    Dec 2010
    Sure would be simple that way. Right click and have a list of all PIDS in log then click the ones you want to see! Simple! That is the way TunerPro RT is set up...
  7. #187
    Quote Originally Posted by Rich Z View Post
    Just a thought....
    In the V8 scan tool you can do just that. Just right click on the PID in the chart and select "Options->Show PID" to hide/show the PID.
  8. #188
    Dec 2010
    Is it safe to start learning the V8 Scan Tool? I've never touched it.
    My understanding is V8 is going to replace all V7.5 stuff?
  9. #189
    Quote Originally Posted by EagleMark View Post
    The V8 Scan Tool will open/display existing V7 log files. It doesn't support pass-thru scanning yet.
    The charts are fully operational, the gauges and maps are still under development.
  10. #190
    Nov 2006
    Suport for Dodge gas engines,
    any chance of this happening?
    LC-1 WBO2
  1. T43 Ideas
    By oztracktuning in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 9th, 2009, 02:12 PM
  2. E67 2.4 LE5 With VVT any Ideas?
    By Quasimotor in forum E37, E38 & E67 PFI ECM's
    Last Post: January 31st, 2008, 11:03 AM
  3. Any ideas up front
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2005, 02:20 AM
