Results 11 to 20 of 21
Thread: CSP5 DATA LOGgING INOP
    May 2009
    Awesome PID selection! I see some long desired parameters!
    Nov 2010
    Default CSP5 DATA LOGgING INOP
    Yes i just tested it and "Validate PIDs" is MANDATORY!!!
    Other than that it's perfect
    Sent from my iPhone using Tapatalk 2
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    [email protected]
    www.youtube.com/ljszmidt
    Quote Originally Posted by cumminsDK View Post
    I clicked on the validate pids icon and bingo it worked otherwise would not allow me to select. I guess I was just spoiled with the software always doing it for me!
    Just make sure the EDA PID's are still the only group selected or it will slow the logging rate down considerably as it drops back to factory mode.
    May 2009
    Right! Should rarely need a pid not included in EDA!
    Junior Member jordylee18's Avatar
    Oct 2011
    Default Re: CSP5 DATA LOGgING INOP
    External thermocouple pids are nifty!
    I wish one of the two available was included in EDA.
    May 2009
    Those are handy but my test trucks have them and not feasible in customer rigs most if the time would definitely be a plus for competition set ups
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    Validating PIDs did the trick. If I switch tunes 2 or 3 times when data logging the V2 will stop working. I have to unplug it for the pc and then it will start working again. Is this normal?
    Nov 2010
    Quote Originally Posted by garrettg.bpd View Post
    Are you bbl with v2 plugged into computer at the same time?
    Les Szmidt
    2007 5.9 Dodge Ram
    [email protected]
  9. #19
    May 2009
    One issue I have had I named the tunes in v8 and programmed v2 names were correct then somewhere in the haste of trying to get EDA to work in v7 the names changed. All names in incremented up one spot, 1 moved to 2, and 2 to 3 and so on. The name for five is gone and tune 1 is named just that "tune #1" on the v2. The names are still correct in v8. I have erased and renamed in v8 and reprogrammed but they remain the same. Small issue and names aren't real critical but an issue none the less.
  10. #20
    Nov 2010
    They changed in the v2?
    I'm not quite following...
    Les Szmidt
    2007 5.9 Dodge Ram
    [email protected]
  1. Data logging help!
    By 05longbed in forum AutoCal
    Last Post: November 27th, 2013, 12:18 PM
  2. data logging
    By Gwoody in forum Cummins 5.9L
    Last Post: December 1st, 2012, 09:31 AM
  3. Data Logging NEED HELP
    By dodgeram5-92500 in forum Cummins 5.9L
    Last Post: August 23rd, 2012, 11:39 PM
  4. Data logging
    By dannyperform in forum General (Diesel)
    Last Post: June 21st, 2012, 04:45 AM
  5. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
Tags for this Thread
