Results 1 to 3 of 3
Thread: Tunning for 160# Bosch injectors
    Mar 2010
    Default Tunning for 160# Bosch injectors
    I'm sure this has been beaten to death, but I am contemplating running the Bosch 160# injectors on my Turbo E85 car. Currently I have 120# injectors in and running decently.
    The advertised min. pulse width for these injectors are 1.6 msec, so in {B4003} if the value is below 1.6msec won't the injector stay shut? Or is there somewhere else to enter data in for the injector offset (ie time to open and shut injector)
    Also for the voltage adjustment, the data Bosch publishes does not take in account to manifold vacuum, how are most people scaling that data?Click image for larger version.
    Does anyone have a successful 160# injector tune they could post up?
    Thanks!
    Senior Member JUSTASBC's Avatar
    Aug 2010
    What actual injectors are you using? I am in the process of switching them over in my truck for E85.
    05 Joe Gibbs black RCSB ram air hood, Leer tonneau, blacked out tail and head lights. Forged 370, Eagle crank, Wiseco pistons, Compstar Rods, Pro Flo XT intake, KB Racing log, spool valve, T6 S480 1.32 A/R, boost activated cutout, TSP 2.5 5.3l heads, Comp Cam 224/230 .600 with rockers, comp cams 1.75 roller rockers, dual Walbro 450's, Injector Dynamics id1300's, 4l80e w/3200 multidisk Circle D, trutrac w/3.73's, 3"DI/DO Magnaflow, tips through the roll pan, running COS3 Semi OLSD OS#12592618
    Jun 2010
    I know this is an older thread but I was directed here by racetronix support
    The injector information posted in the OP is incorrect, that is the injector info for the FRPP 120# injectors part number # E303
    http://www.efidynotuning.com/injdata.htm
    If anyone has any bosch info on the 160s please do post back or email me, email in sig
    decipha @ efidynotuning
  1. BOSCH Fuel Injectors 0280155868
    By mr.prick in forum Gen III V8 Specific
    Last Post: February 11th, 2020, 01:46 PM
  2. tunning for bigger injectors
    By gigabrock in forum Duramax LB7
    Last Post: February 18th, 2015, 04:06 PM
  3. Bosch Motorsports100hp injectors and timing/fuel rattle
    By cumminsDK in forum Cummins 5.9L
    Last Post: July 10th, 2012, 03:12 PM
  4. IFR table for red 30# Bosch gen 3 injectors
    By bsomm in forum Gen III V8 Specific
    Last Post: April 1st, 2009, 01:05 AM
