Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: calculated pid not valid for NGK/NTK Air-Fuel Ratio Monitor
    Jun 2014
    Default calculated pid not valid for NGK/NTK Air-Fuel Ratio Monitor
    Can anyone see where the error might be? Or suggest to me what I am doing incorrectly to cause this message?
    Feb 2012
    That cal_pids file is empty.
    Jun 2014
    Oops.
    This may be more helpful.
    You forgot the closing double-quote at the end of CLC-00-003.
    Jun 2014
    Thank you. That got it working. Unfortunately my formula must be wrong. My afr is reading 4 points to low. NTK suggest {(vout-0.5)x2.75}+9
    I have:
    *CLC-00-003
    AFR 9.0 20.00 .1 "{EXT.AD1}-0.5*2.75+9"
    What fuel are you running...?
    Jun 2014
    Vp c14
    C14 contains lead which may foul your wideband sensor, but IDK if this is significant... do you see any signs of this...?
    C14 has stoich AFR about the same as pump gasoline.
    Test your wideband sensor:
    what voltage do you see when sensor is in free air (should go all the way lean)...?
    what voltage do you see when you cover the sensor with a rag dampened with brake cleaner (should go all the way rich until the brake cleaner finishes evaporating)...?
    Jun 2014
    Sensor reads 14s at an idle on the NTK monitor that the sensor came with. Sensor is new. Yes the sensor goes to 20 in free air.
    I know lead is not good for them but they last a while to dial in the tune.
    I am fairly confident my problem is with my formula.
    Jun 2014
    Still hoping someone would be willing to help me out with the proper calculations to make wideband read correctly.
    I'll keep reading.
  1. Air/Fuel Ratio Adjustment
    By kylelavergne in forum Gen III V8 Specific
    Last Post: December 26th, 2013, 04:22 PM
  2. Air Fuel Ratio or Timing for Peak Power
    Last Post: September 23rd, 2009, 04:42 AM
  3. Air-Fuel Ratio Monitors
    By Sid447 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 24th, 2009, 09:45 PM
  4. AFR Command Air Fuel Ratio
    By james01ss in forum Gen III V8 Specific
    Last Post: October 6th, 2008, 01:33 PM
  5. Air Fuel Ratio
    By batesyellow01 in forum Petrol / Gas
    Last Post: March 15th, 2007, 03:25 AM
