Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Aem failsafe gauge not serial
  1. #21
    Aug 2007
    COOL , Thanks guys!!!
    00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
  2. #22
    Aug 2007
    Thanks again guys! It is up and logging. However , I am somewhat fuzzy on which map to use. I have always used afr on my serial lm1/lc1. The lambda looks nice. Just want to make sure my copy and paste works correctly. Any tips to stay on the right track?
    THANKS
    guessing BENW02(AVERAGE) is what map I need to log for my fuel corrections???
  3. #23
    Sorry I had a problem with my internet connection, I just got it fixed...
  4. #24
    Quote Originally Posted by Slowrc View Post
    THANKS
    If you are using only wideband, then use CALC.WO2BEN (average).
    If you are using wideband and LTFT, then use CALC.SELBEN (average).
  5. #25
    The calc_pids.txt file that Joe posted has been somehow corrupted. I've fixed it and attached it to this post as a zip file.
    After unzipping the calc_pids.zip file so that the calc_pids.txt file ends up in the \My Documents\EFILive\V7.5\USer Configuration folder, re-start the V7.5 Scan Tool software and make the following PID selections:
    Attachment 17295
    Thanks Paul
    I edited that calc_pids.txt from my MacBook and it looks like TextEdit thought it was a formatted file (even tho it is supposed to treat .txt as plain text)...
    (and then my internet connection failed when I was trying to post an unformatted file)
  6. #26
    Aug 2007
    Really appreciate you guys!!! Logged t hi morning to work . Worked great.
  1. AEM Wideband Serial Hook-up -
    By RamAir in forum Petrol / Gas
    Last Post: May 29th, 2013, 11:03 AM
  2. 06 LLY Fuel Gauge - empty gauge with 7 gallons left
    By timvan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 5th, 2009, 02:35 PM
  3. Problems with AEM Uego serial logging....
    By BlackGMC in forum FlashScan V2 BB Logging
    Last Post: July 19th, 2008, 04:53 PM
  4. AEM Gauge type 6 in 1 WB UEGO controller
    By JET LEE in forum Gen III V8 Specific
    Last Post: January 25th, 2007, 09:25 AM
  5. Anyone using AEM WB?
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 25th, 2006, 04:02 PM
Tags for this Thread
