Results 1 to 3 of 3
Thread: e38/t43 commanded idle issue
    Apr 2006
    Default e38/t43 commanded idle issue
    got a car that has a commanded idle issue. its a 70 implala swap with a current performance harness
    in park the commanded idle follows the in p/n idle table when you shift it into gear it goes to 896 rpm commanded no matter what you set idle speed in gear at,
    car came from another person whe chopped all the tables up chasing the issue and the first thing i noticed was the commanded idle rpm problem
    any thoughs
    thanks
    Log_0000.efi
    base_0010.ctz
    Aug 2010
    Someone has "tuned" it using HPT. Would recommend beginning with a stock tune, and making your own adjustments.
    Below is a JPEG of the Idle table that is causing the issue ...
Name:	2013 Camaro E38 - in gear idle issue.jpg
    Apr 2006
    Is there a cax for that table? Or can you just set it all to 750. This car was tuned somewhere else and I really don't want to be married to this car. Just trying to help out a freind.
  1. T43/E38 Scaled Shifting
    By Webbs in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 17th, 2015, 02:09 AM
  2. T43 Autocal V2 Licensing Issue and knowledge confirmation.
    By TBMSport in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: March 27th, 2014, 10:44 AM
  3. AutoVE commanded AFR issue
    By ttls1 in forum General
    Last Post: November 30th, 2013, 12:28 AM
  4. Commanded PE AFR Issue
    By nm2769 in forum Gen III V8 Specific
    Last Post: July 9th, 2008, 12:10 PM
  5. Wont go PE when commanded E38
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: October 19th, 2007, 12:19 AM
