Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 139
Thread: 600 rpm slip limit solved!!!! OS 25941752
  1. #111
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    There is one op system that hasn't had it added in yet.
    Dan's Diesel Performance
    www.dansdieselperformance.com
  2. #112
    Aug 2008
    Quote Originally Posted by dansdieselp View Post
    Ohh well that's probably mine. So if I switch to a different os I should see it
  3. #113
    Mar 2009
    The 01 OS's don't have it mapped out, pretty sure all of the 02+ have it. If you're still not getting lockup in 2nd after you have changed the slip limit tables, go in to D5064, and lower the speed down for the lockup speed by 2-3 MPH or more, that should get you lockup. Even if you change the slip limit, you have to have the lockup speed low enough that there is a buffer between the 2-3 shift and the lockup speed, otherwise it won't lockup regardless of the slip limit settings.
  4. #114
    Apr 2009
    Quote Originally Posted by THEFERMANATOR View Post
    The issue he has is with a LBZ A40. I know which one he is talking about.
  5. #115
    Dec 2011
    actually all the slip limit tables in efi are referenced to the wrong memory location as i have discovered based on the fact that i know what table needs to be modified. when i load my working 1200rpm slip limit tune into efi it show me a slip limit of 625rpm, i can change my 1200 limit to anything i like and reload in efi and it still shows 625. its so easy, i dont know how they messed up the reference location.
    2007 Classic CCLB, LBZ - EFIlive, Custom 4 inch downpipe and exhaust, Stock trans with BD tripple disk shimmed relief and modded knockdown valve.
    35/12.50/17 Toyo Open country MT's
    1987 Toyota 4x4 8" lift, 35/13.5/15 Toyo open country's, Trail gear suspension, 22r turbo on Propane @ 20psi boost GT2860RS turbo, V6 R150 Transmission.
  6. #116
    Jun 2016
    Quote Originally Posted by mitchd View Post
    Too much copy pasta.
  7. #117
    Junior Member DAVe3283's Avatar
    Sep 2009
    If you want to send me a .bin file and the address, I can make a CAX file so you can edit it in EFILive. Might help some other people out.
    Sent from my FlashScan V2
    Some diesels, some gassers... EFILive all the things!
    EFILive + RoadRunner = AWESOME!!!
  8. #118
    Dec 2009
    I hope something becomes of this to help. I adjusted the table for my LMM and it reduced but did not eliminate the problem. Only Ben's lockup box actually cured it for me.
    2008 LMM
  9. #119
    Mar 2009
    Quote Originally Posted by n2brk View Post
    Have you also lowered the lockup speed in 2nd gear? It doesn't matter if you raise the slip limit, if you are to close to the lockup speed in that gear, the TCM will over ride lockup until the shift is completed. I think this is the issue alot of people are running into with no lockup even after raising the slip limit.
  10. #120
    Dec 2012
    There are also a few more speed related lock up inhibitors not in EFI. Two that dictate min enable disable and an base value minimum speed lockup can occur at. If those are not lowered, in most OS's I have come across, the soonest possible you can get the TCC to lock is ~ 20 MPH. Which is close enough to the 2-3 shift that it will 90% of the time lock immediately as it enters 3rd Gear. Without changing those, Ben's box will always lock sooner.
    Quote Originally Posted by LunchBox View Post
    LOL Its so true!
    Josh
    '04 GMC LLY
    '05 GMC LLY - L5P Conv. w/ E41 vpw comms, 6-Spd Conv. ML Trans
  1. 600 rpm slip limit
    By killerbee in forum Allison 5 & 6 Speed
    Last Post: December 2nd, 2012, 07:00 PM
  2. Fuel and RPM limit question...
    Last Post: June 2nd, 2010, 11:56 AM
  3. speed/RPM limit cancel!!
    By A.O.A in forum General (Petrol, Gas, Ethanol)
    Last Post: May 27th, 2009, 05:44 AM
  4. RPM limit
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 7th, 2008, 05:41 PM
  5. High RPM power loss solved
    By PSWired in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 16th, 2005, 12:43 PM
