Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 71
Thread: Known Issues With Current Public Release
  1. #21
    I even did a format on the bbx when i did the update.
    Log_scanner_0013.efi
    that's a log via the 7.5 pass through.
    BBX
    E98_0048.efi
  2. #22
    Also noticed that when you do a compare with tunes, you can no longer double click on the item and get taken to the table etc.
    This seems to work ok for me
    ( except, of course, for the VVE tables, their diff's don't show up... but the VE coefficients diff's show up ok, and double clicking on that takes me to that table ).
  3. #23
    Junior Member SwedeBurb's Avatar
    Jan 2008
    Default AutoCal Settings
    With the v2.07.108 firmware I'm having an issue editing AutoCal splash text lines... Text 1 is empty and Text 2 reads "ive Auto". When I try to save new text values I get, "Error $0106: Received data contained parameters that were out of range.".
  4. #24
    When using the compare feature in the V7.5 tune tool I can no longer double click on the differences and be taken to the table.
    04 LB7
    2010 LMM
    2015 LML
  5. #25
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    Quote Originally Posted by SwedeBurb View Post
    We are having the same issue here as well.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
  6. #26
    Nov 2016
    Having similar problem with my FlashScan. Same error and the FlashScan screen is washed out, unreadable. Can't update anything to the FlashScan.
  7. #27
    Another potential issue with the latest firmware, I had my screen timeout/sleep mode set to 2 minutes and was getting constant drop outs & could see the v2 turn off then on again while pass through logging. Might be soemthing gone wrong there too.
    I changed it to 5 minutes but laptop went flat so havent tested to see if it still does it. BBX was working fine though.
  8. #28
    Dec 2014
    Same issue here.
  9. #29
    Nov 2005
    Default Known Issues With Current Public Release
    Software updates for V7, V8 and firmware are now available to fix the Cummins recovery issue and Error $0106.
    Customers running the December public release can use the Check for updates options. I'll update the software links in this thread tomorrow. Updates Links are on our website.
    Thanks for your patience during our holiday break.
    Cindy
    Sent from my iPad using Tapatalk
  10. #30
    Dec 2014
    Awesome, thank you. Tested and no more $0106
  1. Known issues with the October 2015 Public Pre-Release
    Last Post: November 14th, 2015, 10:09 PM
  2. Known issues with the September 2015 Public Pre-Release
    Last Post: September 11th, 2015, 10:46 AM
  3. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  4. Known issues with May 01, 2015 Public Release
    Last Post: June 2nd, 2015, 10:46 AM
  5. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
