Results 1 to 10 of 14
Thread: Calc.vet how do I populate selben/ve maps? Can't find in log file. Joecar?
    Jul 2015
    Default Calc.vet how do I populate selben/ve maps? Can't find in log file. Joecar?
    Okay, so I've gotten everything set up, pids validated, map filter parameters preset, etc.etc. and am ready to start logging. Working with a 98 and v1. Have followed tutorial to the T with wideband / b4901 dynair lookup replacement pid etc.
    I took a preliminary log last night to dry run through the maps and filters and though I have figured out how to create a map, or even copy my ve table from the tune as per the efilive map tutorial, I am left unsure as to what I need to do with a log file to create the selben and ve maps. Should it be an auto populated map that I choose from a drop down menu or do I need to manually create a map defining the rows/columns? I ask because the tutorial doesn't make a mention of creating a map, just says to paste the ve map/paste multiply selben/maf map. Makes me kinda think I am missing something here. Thanks for any help!
    In the scantool, goto the Maps tab and view the map you created, the current log should populate it...
    post some screenshots so I can see what you did.
    The Calc.VET thread tells you to goto tunetool and copy with labels, then goto sacntool map properties, and on Row and Col tabs to click Paste Special.
    Jul 2015
    Joecar,
    Yup... That would be the problem. I've been over the tutorial and the advanced notes dozens of times but I must be missing that part. I thought the copy/paste was only mentioned in reference to the pasting of the populated map to the existing tune. D'oh! I thought it felt like I was missing something stupid
    no worries, it's easy to miss stuff like that (especially when I speed read).
    Jul 2015
    well, I looked through everything again... I must be missing something... can I get a link with directions on where to find the instruction for preparing the map? ive followed what I can gather and this is what I came up with:
    I would like to add I'm using the innovate mtx-l plus analog out with flashscan v1.... thus far the only pid that seems correct is LC-1, is this the right option? I do not see an option that is clear cut for this wideband
    I will try to find a way (probably the wrong one!) to try to make it be as I think it should
    Jul 2015
    okay, so what ive done is this.... taken a log, gone to maps tab, clicked "open a new map definition for display", found CALC.VET g_K_kPa.map, selected that, gone to "edit map properties" and I receive this :
    forging on, I click "OK" on "list index out of bounds", set columns tab as such :
    and set rows tab as such:
Name:	vemap 2 row.png
    and am left with this for numbers after everything replotted , for cell count and average value views. note this is a cruise map on the interstate driving home
    This is the current calc.vet filter settings I have and the resulting data. Since I have a 170 degree tstat, the filter temperature has been lowered to 160 degrees to ensure data isn't filtered out
    I cannot for the life of me find any reference as to how to set up the selben map. I do not find a preset map data under maps like I did for calcVET map.
    Apologies for the flood of crap here... I figured this might be the most concise way to determine if I'm headed the right direction
    disregard the "attatched thumbnails"..... paint / me had a problem
ID:	21427   Click image for larger version.
ID:	21428   Click image for larger version.
ID:	21429   Click image for larger version.
    Quote Originally Posted by estringer View Post
    That looks right for a VE map.
    Yes, for the LC-1 you can use CALC.BEN_LC11.
    Hmmm, "list index out of bounds"... which V7 build version are you using (Help->About)...?
    that looks right.
    On the Data tab, set the Precision to 3 or 4.
    Change the filter as shown here:
    in tunetool goto B5001 MAF table, in upper left blank tile do rightclick->Copy-with-Labels;
    in scantool goto map properties, on each of Row and Col tabs click Paste Labels;
    on Col tab, for the pid, use any pid already logged (e.g. MAFFREQ or RPM);
    also, on Cell tab, constrain the cells' width.
    No worries.
    I edited the Calc.VET thread to show how to make maps, see item 3 inserted (previous item 3 is pushed down):
    Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
    Jul 2015
    Thanks for all your help Joecar! I think I might actually get this to work...
    my version is 7.5.10
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Low SELBEN's with Calc.VET?
    By ferocity02 in forum Gen III V8 Specific
    Last Post: May 27th, 2013, 02:02 PM
  3. Sanity check of my first CALC.VET log.
    By bimbleuk in forum Gen III V8 Specific
    Last Post: April 21st, 2013, 05:41 AM
  4. Setting up for first log for calc vet tune.
    By Laychut in forum Gen III V8 Specific
    Last Post: April 28th, 2012, 08:58 AM
  5. Tried to use Calc.SELBEN can someone look at my log
    By pavetim in forum Gen III V8 Specific
    Last Post: February 5th, 2011, 04:21 PM
