Results 1 to 5 of 5
Thread: GM E80, E82, E83, E84 ECM bench harness diagrams
    Oct 2017
    Default GM E80, E82, E83, E84 ECM bench harness diagrams
    Hi. I need diagrams for E80, E82, E83, E84 ECM bench harness. If someone has some schematics I will thank you very much.
    Big ask for a first time poster
    Oct 2017
    Yes, you are right. And this is why I found what EFI Live does and know about this forum. If you have no problem with a newcomer and have some info to share with me I will thank you so much.
    Oct 2017
    I am trying to make bench harness for most newer GM ECMs. This is the information that I found here and in some other forums. I like to share it here with you so you can see that I am not just asking for help but contribute with something (altrough I just made a copy and pase):
    E37:
    Black Connector:
    Pin Signal
    8 Ground
    19 Ignition
    20 Battery
    43 CAN +
    44 CAN -
    E78:
    Blue connector:
    J1-19=battery pos
    J1-20=battery pos
    J1-43=can low
    J1-29=can high
    J2-13=switched 12v+
    J2-28=switched 12v+
    J2-73= gnd
    E39:
    Blue connector:
    J1-20= gnd
    J1-30=gnd
    J1-39=can high
    J1-40=can low
    J1-51=switched 12+
    J1-52=battery pos
    J1-71=switched 12+
    J1-73=switched 12+
    be sure to use a power supply rated for at least 3 amps as the e39 pulls a lot of current
    E78 is the same as the mt-88, Entrol 88
    we also put an led on the fuel pump relay pin to see if the cal is valid
    E92 in attached image:
    Attachment 21552
    Dec 2020
    Quote Originally Posted by araes View Post
    E37:
    Black Connector:
    Pin Signal
    8 Ground
    19 Ignition
    20 Battery
    43 CAN +
    44 CAN -
    E78:
    Blue connector:
    J1-19=battery pos
    J1-20=battery pos
    J1-43=can low
    J1-29=can high
    J2-13=switched 12v+
    J2-28=switched 12v+
    J2-73= gnd
    E39:
    Blue connector:
    J1-20= gnd
    J1-30=gnd
    J1-39=can high
    J1-40=can low
    J1-51=switched 12+
    J1-52=battery pos
    J1-71=switched 12+
    J1-73=switched 12+
    Attachment 21552
    hi i need the e92 harness bench anyone ??
    thanks albert
  1. PCM Bench Harness Wiring diagrams
    Last Post: April 28th, 2015, 05:51 PM
  2. Bench Harness?
    By GAMEOVER in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 31st, 2009, 11:33 AM
  3. bench harness
    Last Post: June 15th, 2006, 05:09 AM
  4. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 09:34 PM
Tags for this Thread
