Results 1 to 4 of 4
Thread: Can V1 scan individual cylinders for misfire?
    Oct 2006
    Default Can V1 scan individual cylinders for misfire?
    Forgive me if this is a dumb question, but I've been out of the tuning game for some years (after getting my car nicely tuned). If so, how do you build the scan file?
    2000 Formula: 12212156, bolt-ons, 3600 stall, 3.42's.
    There are pids that indicate the per cylinder misfire counts, and these are loggable with V1 and V2 (and any advanced scanner)...
    log at these pids:
    GM.MFCYL1C
    GM.MFCYL2C
    GM.MFCYL3C
    GM.MFCYL4C
    GM.MFCYL5C
    GM.MFCYL6C
    GM.MFCYL7C
    GM.MFCYL8C
    GM.MFTOTAL
    on the PIDs tab, select those pids (and the usual ones, SAE.RPM, SAE.MAP, SAE.MAF, GM.TP, GM.SPARKADV, ...),
    within the PIDs tab click the Save Pids button (give it a filename),
    then click the Connect button (green, upper left),
    then click the Record button (red, bottom middle)...
    when done logging, click the stop button (blue square, bottom middle), and save log to file.
    Oct 2006
    Thanks, Joe. Looking into it I did see those misfire pids and except for the total. And I might not have remembered to log some of the other basic data.
    I haven't used EFILive in years except to swap a tune in and out of the car. Creating a pid selection file and it's all starting to come back to me now. Thanks again!
    Oct 2006
    This worked and I observed misfires on multiple cylinders. I'm trying to chase down this issue that has plagued the car since the rocker arms were replaced. Details are in this thread:
    https://ls1tech.com/forums/generatio...pull-head.html
  1. Large misfire count on cylinders 4 and 7
    By bubba68ss in forum Gen III V8 Specific
    Last Post: November 15th, 2014, 06:38 AM
  2. Is there any way to do individual cylinder timing with EFILive?
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: March 15th, 2009, 01:25 PM
  3. Does E38 allow individual injector control?
    By ringram in forum E37, E38 & E67 PFI ECM's
    Last Post: June 23rd, 2008, 09:09 AM
  4. Can you log knock for individual cylinders?
    Last Post: March 9th, 2008, 03:13 PM
  5. Individual wheel speeds
    By Dlong in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2007, 01:30 AM
