Results 1 to 10 of 10
Thread: New to this and need help!!!
    Jan 2018
    Default New to this and need help!!!
    This is my first LS motor swap in my 68 Chevy C 10. What I
    Please go ahead and complete your post.
    Jan 2018
    Quote Originally Posted by RodHewitt View Post
    It runs bad when cold, and OK when it
    What was the donor vehicle...? You got the engine from this...? You got the ECM from this...?
    Did you modify the engine...?
    Did you edit the ECM...?
    Jan 2018
    For some reason it’s not showing my whole replies.
    Jan 2018
    Default Need help
    LQ9 bottom end, LS3 tip end, Headers and an aftermarket cam. 224/230 with a 595/600 lift with a 114+ for lobe separation.
    Jan 2018
    Default Need help
    Runs bad when cold, very rich. Was stalling all the time. I put a Dakota digital 8000 pulse generator speed sensor on it, and it quit stalling every time I came to a stop! That little since remade the drivability a lot better. It
    Jan 2018
    Default Need help
    2003 Escalade PCM/drive by wire tech module
    What Windows OS are you guys running...?
    What PC/laptop device are you running on...?
    Which intake manifold are you running...(probably the LS3 car manifold vs the LQ4 truck manifold)...?
Tags for this Thread
