Results 1 to 8 of 8
Thread: stalling in gear at stop sign
    Jun 2008
    Default stalling in gear at stop sign
    I am trying to help a friend with a LS transplant into a 1993 pickup. It has been at 3 different shops with multiple changes and when he got it back it dies at the stop sign. I noticed when I lift off the gas the rpm's drop down and by the time I get to the stop sign the rpm's drop below the set amount sometimes it dies and sometime the rpm's will come back up and keep running. If I put it in neutral it keeps the idle. I dont have or he doesn't have the factory program from the computer. If anyone could take a look and see if anything stands out.
    Post some logs.
    Sounds like throttle cracker.
    Jun 2008
    Post some logs.
    thank you but not for sure what they were from factory.
    Using EFILive scantool you will neex to log some data so we can see what is going on...
    we want to see what IAC and SPARKADV are doing when it stalls.
    Jun 2008
    I found they turned off the throttle cracker. So it works good in forward gear but when I shift it from park to R it drops down to 600 rpm but from nutrual to D it works alot better. He came and got the truck before I could run some data. Thanks for your help and if you have any ideas why Reverse would be different then Drive
    Lifetime Member Doc's Avatar
    Oct 2005
    Was it electronic TB or cable driven? The VIN / Cal is for a 2003 Truck. Or at least that's what it thinks it is.
    www.efialchemy.com
    www.greatamericancarwar.com
    Jun 2008
    Quote Originally Posted by Doc View Post
    It is electronic TB
    Oct 2005
    Base spark IN GEAR sticks out like a sore thumb with ~28 degrees timing where you would "see/datalog," it going from park or neutral to in gear with your foot on the brake. Look at all the other spark tables...sounds like it didn't like that much timing?
    www.efialchemy.com
  1. How to stop upshift from 1st to 2nd while in 1st gear 2003 silverado 4L60
    By mvvette97 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 19th, 2016, 06:08 AM
  2. Replies: 1
    Last Post: July 19th, 2016, 06:04 AM
  3. Request Help. Stalling when coming to a stop.
    By 2002_z28_six_speed in forum General
    Last Post: June 14th, 2015, 12:24 PM
  4. Why can't I sign in to purchase a license???
    By picnic_george in forum Purchase and Shipping
    Last Post: March 8th, 2014, 10:09 AM
