Results 1 to 8 of 8
Thread: What happend to commanded AFR and Injector PW Pids?
    Jan 2009
    Default What happend to commanded AFR and Injector PW Pids?
    I'm working with a '07 Silverado E38 (OS 12614088). When the scan first starts I see "good" Commanded AFR. But after about 4 seconds it suddenly jumps to 29.36 (twice 14.68). At the same time Injector Pulse Width jumps from 234 mSec (an impossible number) to 456 mSec. I'm using E38AFRATIO_DMA and GM.IBPW1 & GM.IBPW2, same PIDs I use with a '06 Z06 (OS 12605732).
    By the way, thanks to Dragframe's " Interesting Issue: MAF failure = Idle tables ignored. Cant tune VE because of it" thread! Same year / OS. I saw the same MAF problem. That post helped me understand why I could not tune the idle.
    Mar 2010
    Quote Originally Posted by Yellow05C6 View Post
    Yeah that maf fail issue haunted me. I made a big change i need to test to see if it will idle now with the mad failed though. I report back to ya when i get around to failing the maf again. Right now its running surprisingly well MAF-OL. (I have odd issues in closed loop but thats another topic... this 07 e38 is a pain)
    When its coming to the commanded AFR issue... that is bizarre. When i get away from work ill poke around and see if i can find anything. Can you post the tune and log?
    Jan 2009
    This is on a GMPP LS3 DR525 crate engine with a magnuson supercharger.
    BarryNewStart_0009.ctzBarry Cold Start 8-5-2019.efi
    Mar 2010
    Hmm latest update locked older versions from opening its tune files. Ever since HPT and EFILive started deleting epa tables off i dont want to update lol
    Jan 2009
    The GMPP kit uses an E67. This is just the GMPP engine with a non-GMPP harness and an E38.
    Mar 2010
    What I meant is in the latest efi live update, they changed some security stuff and older versions of the software wont open files from the latest software.
    BTW. I figured out my idle issue was table b1703 has a ridiculously low figure like 60 in it. Once I raised that up to match b1701 my idle issue went away in SD. I found other issues tho like trans pressure going bezerk (blew a trans cooler line even). I got two logs in sd, fixed the ve up a fair bit off that, and put the maf back on. My afr is much closer to my commanded afr now.
    Did you ever figure out your commanded afr issue??
    Jan 2009
    I have not had time to tinker with it. I live near ground zero for Hurricane Michael and life has a way of getting in the way of fun.
    GM.IBPW1/2 are for LS1 and E40.
    GM.INJPWB1/2 are for E38, E67, E92.
  1. What PID to scan commanded afr & injector duty cycle for e78
    By wesam in forum E78, E83, E84 PFI ECM's
    Last Post: September 21st, 2012, 06:58 AM
  2. What PID to scan commanded afr & injector duty cycle for e78
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
  3. Commanded AFR not equal to WBo2 AFR at idle.
    By macca33 in forum Gen III V8 Specific
    Last Post: April 6th, 2012, 12:56 PM
  4. AFR Commanded... Where else other than PE???
    By Behold in forum General (Petrol, Gas, Ethanol)
    Last Post: October 27th, 2011, 01:27 AM
  5. Cold AFR doesn't follow commanded AFR
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: August 17th, 2009, 02:50 PM
