Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Interesting Issue: MAF failure = Idle tables ignored. Cant tune VE because of it
  1. #21
    Aug 2013
    Quote Originally Posted by Dragframe View Post
    b1703 is what table needed to be adjusted to allow it to idle without the maf.
    Somehow I missed that when I went through your tune file. Glad you found it.
    I still have a crazy issue with turning on STFT. They jump all over the place with no rhyme or reason. Even at idle. I have them turned off for now. Maybe forever lol
    STFT can bounce around a lot if it's not set up properly. Can you post a log?... I'd like to see how 'crazy' they are.
  2. #22
    b1703 is what table needed to be adjusted to allow it to idle without the maf. It had a really low number like 60 in the field. I just entered the values from b1701 into it and it idled I was able to get my VE table fairly close'ish.
    Quote Originally Posted by statesman View Post
    I believe what was said, I'm just not sure the reason why that table would prevent running MAF at idle.
  3. #23
    One thing to note though... the transmission must default to full line pressure without the maf because after setting everything up to tune the VE... the tranny was banging shifts and blew a cooler line...
    The trans tune would have MAF DTC entries in the max line pressure, you can disable those.
  1. MAF tables
    By bubba68ss in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2012, 01:56 PM
  2. Tune VE and MAF tables or leave VE stock and tune MAF only
    Last Post: August 4th, 2008, 08:05 PM
  3. Strange MAF&MAP tune issue...
    By dc_justin in forum Custom Operating Systems
    Last Post: October 2nd, 2006, 05:45 AM
  4. Interesting idle ? I could not find anywhere
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: August 2nd, 2006, 08:38 PM
  5. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    Last Post: July 11th, 2006, 03:58 PM
