Results 1 to 3 of 3
Thread: "New" A40 TCM compatible with locked ECU tunes
    Jan 2023
    Default "New" A40 TCM compatible with locked ECU tunes
    Hey guys, Quick question here. Have an LMM with locked tunes from Danville. Begged for the code just to be able to adjust some things for driveability in the TCM. Mainly part throttle upshifts and lock/unlock points. Understandably they refuse to let the code out so I am stuck with what I have.
    My main question is if I reflash or "write my own" tcu tune, will it be able to work correctly with locked ecu tunes?,
    The ECM and TCM are locked/secured independently. The locking only prevents reading/flashing - it has no effect on the operation of the ECM/TCM.
    if one or the other is locked it won't affect the interoperability of either.
    So if your ECM is locked and your TCM is not then you can edit/flash the TCM and will will continue to work with the ECM.
    Reards
    Jan 2023
    Awesome, thank you paul!
  1. Changing custom key value in "locked" E67 ECM
    By required field in forum E37, E38 & E67 PFI ECM's
    Last Post: March 4th, 2018, 07:15 AM
  2. A40 in "Engine in Default Mode Shift Pattern"
    By OTHRGRL in forum Allison 5 & 6 Speed
    Last Post: November 15th, 2017, 12:17 AM
  3. "controller locked with custom key" DEAD ECM
    By DURAtotheMAX in forum Duramax LLY
    Last Post: May 14th, 2012, 01:25 PM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. have to flash ECU forProject GenIV "LMG" into 1997 Tahoe
    By harascho in forum Gen IV V8 Specific
    Last Post: April 14th, 2008, 02:55 PM
