I have a 2006 Trailblazer SS E40 ecu, I will skip the reasoning for the upgraded injectors but went from the OEM ones to some FIC #60 ones I downloaded the EFI data for them and input the values that made sense to me. I need to figure out what else i need to log and change to dial it in a little better without a wideband gauge. Unless i need to put one on. Anyways after all the reading i've done still confused on what my first step to do is ect.. It's like the more i read the more i get confused. So far i adjusted the B1203 (Minimum Injector Pulse Width) {B1204} Small Pulse Adjust and the {B4001} Injector Flow Base with the FIC data I think that was correct. Wondering if my next step is to log something which im not sure what and then adjust {B1210} Injector Flow Correction Vacuum?
