My ECM guy (
https://gmtuners.com/ ) sent this service manual info:
I was wondering how people were installing the trigger wheel on-- or simply seeing-- the 13th tooth, or any tooth other than the 14th tooth, *WITHOUT* the ECM setting a P0016. The answer is that the tolerances for P0016 are wide enough that the crank trigger wheel can be off almost two whole teeth in one direction, and more than two whole teeth in the other direction before the ECM will set P0016.
A less obvious consequence is that the ECM still triggers spark based on the 14th tooth. So someone who installs the crank trigger wheel on the 13th tooth has BUILT THEIR ENGINE such that it will inherently have a SIX DEGREE TIMING RETARD vs the values in the tuning software.
That is, base timing is 6 degrees retarded vs where they think it is.
