Results 1 to 10 of 12
Thread: LS2 Tuning Experiences & Tips
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default LS2 Tuning Experiences & Tips
    I know many are interested in discussing the finer points of all the work that is 'best practise' with LS2 calibrations.
    What i have gathered so far is the LS2 are much more fussy with what we do with them and throw a heap of codes easily.
    The VE table is setup differently but the process to get it right is similar.
    Timing in the Australian LS2s looks quite good - interested to see just how much and where we can add some more timing advance.
    So far i have done 2 cars both with medium-big cams.
    Steve
    Redline Motorsports
    Guest
    First......thanks Paul for setting this up! This will make the site much better to navigate.
    I agree, the LS2 is real sensitive to minor changes. Wait to you see the LS7 stuff, its even worse!
    I guess we can let the fun begin! oz, do you have a stock bin we can see from the Aussie cars?
    Howard
    It was not me
    One of the mods probably set it up.
    But thanks to whoever did
    EFILive Distributor dfe1's Avatar
    Jan 2005
    I haven't done any cammed engines yet, but with a stock Trailblazer SS and C6 with headers, I haven't noticed any unusual sensitivity to tune changes, using the same approach as with LS1. I still can't figure out what kind of non-prescription pharmaceuticals the GM calibration engineeers take before developing the original calibrations. A lot of the 3-D graphs look like a topographical map of a mountain range-- not a sensible calibration for an internal combustion engine.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Redline Motorsports
    Guest
    It was not me
    we'll thanks for whoever did!
    HT
    Oct 2004
    Ross would have done it - we don't have access to massage the forums structure
    Andrew
    EFILive Crew
    Oct 2005
    Quote Originally Posted by dfe1
    So you have tuned your TBSS ? Which version do you have ?
    Jan 2005
    V2 with 7.3.3 latest release.
    678/344-1590
    Mar 2005
    Hi there Guys, I've only done 1 Holden LS2 so far. It was bog standard enginewise and therfore presented a real challenge to get real gains from tuning alone
    Interestingly enough we acheived a 8kw repetable "gain" in the top end with 5% torque increase across the RPM under full load. This was achieved by reducing the full load timing to suit our piss water 95 octane fuel we have here in New Plymouth :( and therfore stopped the knock retard from going nuts which take most of the dyno run to roll back up to the high octane table.
    The VE map was almost spot on except at 3200rpm between 50 to 80 kpa during the SD tuning. The lower MAF table was spot on and the upper MAF table needed the usual trim up to stop the over rich top end.
    The customer reported a noticible improvement in throttle response better drivibility and a 0.4l/100km drop in fuel useage on a trip.
    Holden certainly have spent a lot of time on the LS2 calibration to get it right. A huge improvement on the earlier LS1 calibration which were miles out.
    Mike
    A lot of the 3-D graphs look like a topographical map of a mountain range.
    I've always wondered about this too. Maybe I am missing something
  1. Any tips for tuning a 98 turbo?
    By zapp168 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 9th, 2009, 04:54 PM
  2. E38 PCM tuning experiences to share....
    By The Alchemist in forum E37, E38 & E67 PFI ECM's
    Last Post: August 29th, 2007, 11:52 AM
  3. Any tips to using RR and EFILive?
    By Chalky in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 3rd, 2007, 08:22 AM
  4. Autove tuning tips
    By MSGHUFF in forum General (Petrol, Gas, Ethanol)
    Last Post: January 2nd, 2007, 11:52 AM
  5. CheaTR Cam Tips
    Last Post: October 11th, 2006, 03:22 AM
