Results 1 to 10 of 12
Thread: Rewired my 98 Z28 to use 99+ RR PCM and COS5
    Sep 2006
    Default Rewired my 98 Z28 to use 99+ RR PCM and COS5
    I finished the wiring last night. I can get the laptop to connect to the car for scan, and i can connect to the roadrunner. When I try to upload a .cal file for COS5 by selecting "upload operating system" on the roadrunner screen, I get an EFIlive registration error. Tried everything, no luck. Says it everytime I open the software too.
    Anyways, when I get that straightened out, do i just upload the COS5 how I stated earlier? Then fire the car up? I'm a little lost, getting this going for the first time.
    Matt
    '98 Sebring Silver Z28 6spd Hardtop
    T76GTQ single turbo spooling around town
    EFILive FlashScan with 99+ Roadrunner PCM
    '03 GSXR600 Alstare with an '02 GSXR1000 motor
    Nov 2006
    are you using V1 or V2?
    the V1 personal version can`t upload COS.
    Sep 2006
    Quote Originally Posted by mr.prick
    I have the V1 and a commercial scan and tune license...but my registration isn't working for some reason. Do I have to be connected to the internet when registering it in the software?
    I pm'd Tech Support.
    Quote Originally Posted by WestSide
    Matt
    Did you purchase an EFILive/RR license from Moates? It is this product here: http://www.moates.net/index.php?cPath=53_54
    You will receive new EFILive Registration details which include your RR serial number. Then you will be able to use the RR device with EFILive.
    If you already have your new EFILive/RR registration details, you must enter them via the Help->Register EFILive menu option.
    If you purchased your RR second hand, or if the RR has already been licensed for use with EFILive (with a different FlashScan cable), then send the existing EFILive registration details for that RR unit and we'll send you the correct registration dertails for your FlashScan cable. Send details to [email protected]
    Bascially if the RR has already been licensed for use with EFILive, then you don't need to relicense it again if you (or anyone else) wants to use it with a different FlashScan cable.
    Dec 2007
    Hi
    Can't offer you any advice, but i would like to know how much work was involved rewiring the 98 harness to the 99+ ECU and would you recommend it.
    Are you using the RR to run the motor permanently?
    Sep 2006
    I purchased EFIlive and roadrunner through the guys at greenlightmotorsports.
    That is probably who I should be contacting.
    I am the sole owner of these units since I purchased them 6 months ago.
    I am using the HELP->REGISTER EFILIVE everytime, but it never sticks. It always asks me to register.
    Sep 2006
    Quote Originally Posted by SA1
    Hi
    I spent a solid 10 hours or so labelling each wire for where it started, to where it ends up, and swapping the pins around on the PCM connectors. It was a really long night, but I know it will be worth it when I'm able to use custom operating systems and have extended boost tables which I knew I would be better off using instead of the 98 PCM which is extremely limited due to memory.
    I will use the RR unit for the first couple of months until I buy a 99+ stock PCM and rewrite my RR tune onto it.
    Dec 2007
    Thanks for the reply. Seems like quite a lenghthy process and I wish you luck with the results.
    Is there any reason that you will not be running the RR permanently?
    Michael
    Lifetime Member Doc's Avatar
    Oct 2005
    You can get pretty quick with the repin. It is very well worth the effort.
    www.efialchemy.com
    www.greatamericancarwar.com
  1. WTF....i want a COS5
    By Kurtomac in forum Custom Operating Systems
    Last Post: August 14th, 2011, 10:55 AM
  2. COS5 available for this OS?
    By nonnieselman in forum Custom Operating Systems
    Last Post: June 15th, 2009, 12:09 AM
  3. COS5 Help
    By mikeyayell in forum Custom Operating Systems
    Last Post: May 29th, 2008, 03:22 AM
  4. help with COS5
    By FFP in forum Custom Operating Systems
    Last Post: October 4th, 2007, 02:09 PM
  5. went to cos5
    By BACKinBLACK in forum Gen III V8 Specific
    Last Post: August 10th, 2007, 12:34 PM
