Results 1 to 7 of 7
Thread: Scanner Not Picking up Commanded AFR
    Lifetime Member MN C5's Avatar
    Mar 2005
    Default Scanner Not Picking up Commanded AFR
    I'm puzzled, finally loaded XP SP2 and now Efi Live doesn't show any values for commanded AFR. Loading SP2 probably doesn't have anything to do with it but I'm puzzled as to why this value is showing up as 0. I can't use the auto tune without a represented commanded AFR as far as I know. Any help would be appreciated.
    Dennis
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Try uninstalling EFI Live and re-installing it. Also, is the correct PID selected? GM.AFR
    If you have just upgraded your EFILive version to 7.2.3, you must revalidate the PIDs (Shift+F2) once you are connected to your vehicle.
    Mar 2005
    It's working now, I knew once I posted it would fix its self :oops: Now to download the new version. The longer I use this software the more I like it.
    Thanks for the quick answer Blacky..
    Mar 2005
    New question, why would the Commanded AFR be a moving target in open loop? I'm getting readings of 7 through 14.7
    Sep 2003
    After you start the car you have an after start enrichment table that richens the car up richer than the open loop table. If you take a look at the open loop table and take the factors and dived them by 14.6528 you will get the commanded AFR that will move a little. The hotter the car gets the closer to 13.0 the car wants the run in the higher map values
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Jan 2004
    Some of the tables he is refering to are:
    B3632 and B3633 IAT and ECT Initial Temp Enrichment. I found these were also giving me some problems with cold starts so I have since zero'd them out and adjusted my EQ Ratio when in open loop table B3605 to command what I actually desire.
  1. Questions about using the scanner
    By 2000Transam in forum General
    Last Post: February 25th, 2010, 10:46 AM
  2. AVG virus scanner
    By joecar in forum Lounge
    Last Post: July 29th, 2009, 08:59 PM
  3. V2 not picking up AD voltage
    By cyclerage in forum FlashScan V2
    Last Post: September 5th, 2008, 12:41 PM
  4. NE1: WTF Scanner keeps asking for more Fuel
    By Chalky in forum General
    Last Post: September 23rd, 2007, 08:22 AM
  5. Scanner help
    By wickedred in forum General (Petrol, Gas, Ethanol)
    Last Post: June 22nd, 2007, 11:10 AM
