Page 7 of 11 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 104
Thread: BB Logging beta update: March 26, 2008
  1. #61
    Quote Originally Posted by Chuck CoW View Post
    Would it be safe to test it on the "logging" V2 so as not to put myself out of business????
    I really wanna try this!
    Chuck CoW
    Yes try the new firmware on your spare V2, so long as you have at least one V2 left on the current firmware.
  2. #62
    If I connect V2 to vehicle with key off, V2 powers on;
    then when I turn key on, V2 does not detect any controllers...
    how do I get it to detect controllers (other than re-connecting it...?)...?
    Otherwise the sequence is to connect V2 to vehicle after key on.
    Hotkey: Ctrl+OK will re-detect protocols and controllers.
  3. #63
    Lots of comments on this thread have been posted, I am making a list of them and will work though them one by one. I will not answer them directly, unless I need more info. I'll just work on fixing them.
  4. #64
    Jul 2003
    Awesome as always.... thank you paul!
  5. #65
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Just something with Blackbox logging with the V2 and the latest beta firmware on my twin turbo LS1.
    Did a longish log yesterday. Opened it in the latest V7.5.4 Build 44 and got this:
    tried opening it direct from the SD card, copying from EFILive_Explorer and still the same.
    Ive got a copy of V7.5.1 Build 32 and if I open it, it thinks for a couple of seconds (as opposed to V7.5.3 which is instantanious) and then the "This has over 3000 frames, etc..." dialog box and I get this:
    Shame coz I logged some Serial WBO2 stuff I want but I cant see it in V7.5.1 but I will keep it until the next software release Ive done shorter logs and they appear fine.
    Jez
  6. #66
    Jul 2003
    Quote Originally Posted by JezzaB View Post
    Just something with logging with the V2 and the latest beta firmware.
    Jez
    DITTO... i forgot to mention this.
  7. #67
    Quote Originally Posted by 9secVette View Post
    Absolute Nightmare
    Hi 9secVette...
    Actually, it's not a nightmare in any sense of that word...
    This is beta testing... we didn't hose up our PC/V2/PCM, so it's all going rather well... ...
    We're BB logging data and we can post some meaningful logs if you care to view them (see attached... this log contains enough information to diagnose a failing bank 1 cat).
    Of course, you must understand that if you want to beta test, you have to be prepared to expect the worst and to post up any problems/suggestions; if you or your customers depend on zero downtime, then it's best to wait.
    Joe
  8. #68
    Jez,
    Chris,
    Shouldn't you be using build 46...?
    Jez,
    Your first pic looked just like mine... have you tried what post #37 says: showpost.php?p=66308&postcount=37
    Edit: oh, do those 2 pids affect how WB is logged...?
    (my WB is off my car right now, I'm fixing it's wiring)
    Joe
    :Cheers:
  9. #69
    Jul 2003
    Nope.. Haven't tried that... actually... didn't read that... hm.. anyways... wb is very important.. I'm glad at least I can log WB Serial data now and to make matters worse... my RR DIES :(
  10. #70
    Sep 2003
    Default Sparkadv
    It seems that the latest release does not like the SPARKADV PID for the 19980400 OS. It does not show up on the display data, does not show up in the log and when I display the log it is not a valid PID. It is in the Options.ini file and if I pick a 99+ system it is displayed.
  1. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  2. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  3. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  4. BB Logging beta update: May 03, 2008
    Last Post: May 5th, 2008, 02:43 PM
  5. BB Logging beta update: March 20,2008
    Last Post: March 23rd, 2008, 09:13 AM
