Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
Thread: BB Logging beta update: May 12, 2008
  1. #31
    Paul,
    I noticed when recording pids on V2 BBL, the inverse video hotkey doesn't work... I have to stop recording first.
    Joe
  2. #32
    after this update my V2 is not detecting an OB2 module
    and so only external PIDs can be logged.
    i re installed an reformatted and re flashed firmware/bootblock and still no connection.
    IIRC this happened to me before and a reformat of the config files solved it,
    but this time i`m stuck.
    There's a problem with the latest firmware that causes VPW modules (i.e. LS1) to not communicate properly. I'm getting a fix out asap.
    I set the message filter too aggressively and accidentally filtered out some messages that should be being received by FlashScan. I'll relax the filters and post a new version either tonight or tomorrow morning.
  3. #33
    Nov 2006
    i reverted to the last firmware, and now i`m able to connect.
  4. #34
    Default Scantool can't connect to PCM
    Yes, I find build 53/54 is not able to connect to VPW in passthru mode (scantool doesn't detect the ECM/PCM).
  5. #35
    Default Build 54: LS1B
    Scantool doesn't connect to PCM, console log and error report attached.
  6. #36
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Was going to post this last night as I tried to do a tune. Flash and read perfectly but the Scan Tool in passthrough could not detect the ECM. After scratching my head for a while I tried an other version of the scantool and no go so figured it mustbe the firmware. Downgraded the firmware and all is well.
  7. #37
    Paul,
    Joe
    Correct, its a "menu" hot key and only works when in the menu subsystem.
    I could duplicate it in the data logging subsystem.
  8. #38
    Lifetime Member hymey's Avatar
    Jan 2008
    I am unable to log pass thru with the new bootblock. i have tried all the firmware for this bootblock, but still no go. should i reinstall the software or is this a bug?
    cheers
  9. #39
    Hymey = CAN
    Jezza = VPW (am I wrong...?)
    joecar = VPW
    So it looks like passthru is not working on either protocol.
  10. #40
    Nov 2006
    Hymey = CAN
    joecar = VPW
    yeah VPW joe. I watched the status window and it was trying VPW (so it was the correct protocol) but it just couldnt find the PCM. Havent gone outside and tried the CAN based car yet (Holden VE).
  1. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  2. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  3. BB Logging beta update: May 03, 2008
    Last Post: May 5th, 2008, 02:43 PM
  4. BB Logging beta update: April 14, 2008
    Last Post: April 23rd, 2008, 08:46 PM
  5. BB Logging beta update: March 26, 2008
    Last Post: April 6th, 2008, 06:43 AM
