Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 106
Thread: BB Logging beta update: May 19, 2008
  1. #21
    You can raise the 50,000 frame limit in the Properties window on the Logging tab page.
    I'll change the auto re-plot to be x1000 (the same as the frame limit in the Logging tab page). i.e. that will turn the 30,000 limit into 30,000,000.
    Hi Guys,
    I've performed 2 logs today that are over 50,000 frames long. Both load in ScanTool after fixing the PIDs and both are truncated at 50,000 frames. The scroll bar allows you to scroll past the end of the data in ScanTool, but the lines just stop at the 50,000 frame mark. The Metadata indicates that there are a lot more than 50,000 frames....
    FRAMECOUNT=00092371
    FRAMECOUNT=00057076
    I've attached a screen shot to show the screen.
    By the way, is there any chance we can get the "Auto Replot" limit raised? It seems to have an internal limit of 30,000.
    Simon.
  2. #22
    swingtan
    Guest
    Excellent! Sorry I missed that.
    I take it that the reason was to prevent overly long "re-plot" times for large logs. In this case, it would be good to have a process where the re-plot is done in the background for the data outside the current window. Then as you scroll across, the additional data is plotted "on the fly".
    I'll settle for a detailed explanation on the "dynamic fueling" options though....
    Simon.
  3. #23
    Simon.
    Given the speed of today's PCs the replot times should only be a second or two at most for 100,000 frames. Unfortunately when the scan tool software was designed one of the goals was to keep the logged data on disk at all times - not in memory. That is what slows it down and why the auto-replot option (kludge) was added.
    Version 8 has all new strip charts (with data purely in memory) and I have benchmarked them plotting 50,000 frames in less than a second on a 1.8GHz Pentium. So it should not be be an issue in version 8.
    Can't help on the dynamic fueling right now :(
  4. #24
    swingtan
    Guest
    Version 8 is sounding great.....
  5. #25
    Unfortunately, sounding great and actually delivering it are two very different things :( But we'll get there as soon as we can.
  6. #26
    Lifetime Member hymey's Avatar
    Jan 2008
    Hi fellas, I still can't get pass-through to work..With BBL all the dma pids are recording and displaying in the scan tool but They are not showing up on the PC when I upload them. The coil temp and inlet valve temp have GM in front of them instead of E38(unsure where to change this). They show up with red crosses in the log. The rest of the dma pids do not show up at all. Only time the BBL has not worked for me.
    Joel
  7. #27
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    Default Serial WB pass through for AutoVE etc?
    All hooked up and displaying on V2 for serial WB (LM-1) and External pids found in 7.5 but invalid and not supported when trying to pass through to 7.5 build 56?
    Are there canned instructions for the BBL and pass through?
    PowrMax Performance
    100 mm PowrMAF
  8. #28
    I will be working on the pass through problem today and over the weekend if necessary.
  9. #29
    Oct 2003
    Sure works swell at the V2 level, now if we can just stuff it up the wire to the MAPS/dash!
    PowrMax Performance
    100 mm PowrMAF
  10. #30
    swingtan
    Guest
    Quote Originally Posted by hymey View Post
    Joel
    Joel, I mentioned this a couple of posts back and I think you may be confusing the issue a little bit. I don't think the Pass-through issue and the DMA PID issue are related.
    The BBL issue where DMA PID's don't display is just that the Meta-Data in the log file is using the wrong PID names. You can get a copy of HEXEdit which is a free download to alter the log files and make the DMA PID's work again. After installing HEXEdit, open a log file and scroll down a little to find the meta-data. In the right hand side of the HEXEdit page, it will look like this... ( surplus removed data shown as | )
    Code:
    [FILE],2..VERSIO
    N=7.1..DECSEP=..
    .[VEHICLE],2..VI
    N=6G1ZK54H26LXXX
    XXX..OS=12607218
    ..[PID],23..SAE.
    ECT=0..SAE.IAT=1
    ..GM.INVLVTMP_M=
    2..SAE.MAP=4..GM
    .APCYL_M=5..SAE.
    RPM=7..SAE.SPARK
    ADV=9..GM.ETCTP=
    10..SAE.VSS=12..
    GM.KR=13..GM.OCT
    SCL_M=14..GM.AFR
    ATIO_M=16..EXT.W
    O2ST1=18..EXT.WO
    TE=2454610..STAR
    TTIME=18436..[En
    d_Of_Meta_Data],
    Find the PIDs that don't show up and note the "GM" prefix, highlighted in BLUE above. HEXEdit will be in "Over Write" mode by default, so press the <Insert> button on the keyboard to enter "Insert" mode ( check the bottom right hand corner of the screen ). Place the cursor just in front of the "GM" by clicking with the mouse, then press <DEL> twice to remove the "GM". Then type in "E38" to insert the "E38" prefix. Do this for each PID that is named incorrectly in the log file. When done, it should look like this...
    Code:
    [FILE],2..VERSIO
    N=7.1..DECSEP=..
    .[VEHICLE],2..VI
    N=6G1ZK54H26LXXX
    XXX..OS=12607218
    ..[PID],23..SAE.
    ECT=0..SAE.IAT=1
    ..E38.INVLVTMP_M
    =2..SAE.MAP=4..E
    38.APCYL_M=5..SA
    E.RPM=7..SAE.SPA
    RKADV=9..GM.ETCT
    P=10..SAE.VSS=12
    ..GM.KR=13..E38.
    OCTSCL_M=14..E38
    .AFRATIO_M=16..E
    XT.WO2ST1=18..EX
    .[End_Of_Meta_Da
    ta],
    Click <file>-<save as> and choose a new file name so you don't overwrite the original ( just in case something went wrong... ). Opening the file in ScanTool should now display the DMA PIDs correctly.
    I'm not sure about the pass-through issue, I haven't tried it. I'll give it a go later and see if I can log in pass-through.
    Simon.
  1. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  2. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  3. BB Logging beta update: May 03, 2008
    Last Post: May 5th, 2008, 02:43 PM
  4. BB Logging beta update: April 14, 2008
    Last Post: April 23rd, 2008, 08:46 PM
  5. BB Logging beta update: March 26, 2008
    Last Post: April 6th, 2008, 06:43 AM
