Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 83
Thread: Tutorial: Log Fuel Pressure in EFILive
  1. #71
    Jul 2008
    Thanks!
    forged LS1 I Patriot Stage III heads I Patrick G spec'd TR grind Comp Cam I ProCharger I High Tech Transmissions I Ultimate Converter Concepts I tuned by cablebandit (soon to be me) @ MSS I Exotic Exhaust & Fabrication custom exhaust
  2. #72
    Jan 2005
    de nada
  3. #73
    Oct 2005
    I'm having problem sourcing the -4an female to 1/8 npt female adapter fitting mention in the tutorial. Any help appreciated.
  4. #74
    Jul 2008
    Quote Originally Posted by voda1 View Post
    got mine from the local Hydraulic Supply
    http://www.hydraulic-supply.com/html/rrlocal.htm
  5. #75
    Nov 2006
    I used a regular NPT to flare adapter from my local hardware store.
    No leaks.
    IIRC it is 1/2" to 1/8"npt
    LC-1 WBO2
  6. #76
    Oct 2005
    Everthing I come across in female 'an' is swivel.
    Edit:
    Found something but is of 2pc -
    -4AN female to 1/8 npt male adapter -- Russel #614204 or Earl's #916104
    1/8 npt female coupler -- Russel #661440 or Earl's #991001
    Came across 1pc design:
    http://www.metcomotorsports.com/prod...p?prod=MFF0001
  7. #77
    way old post but im wondering if you can hook this up to work through the egr on my truck. it is a 2000 k-series and i am running the 411 pcm swap on cos3. would be using an AEM fp guage.
  8. #78
    Nov 2006
    If you can log voltage through the EGR and you can get the slope & intercept to convert
    voltage to FP, then yes.
    LC-1 WBO2
  9. #79
    Jul 2009
    Can anyone see why this sensor wouldn't work instead of the autometer 2246.
    (J.C. (240)P399AAC-1C PRESSURE TRANSDUCER O TO 100 PS1S) can be found on ebay for less than $60 and bolts directly to the schrader valve port without removing the valve - no need for adapters. Its advertised as being designed for measuring refrigerant pressure but the literature says it can be used with any non corrosive fluids.
    Here are the specs
    http://www.vikingcontrols.com/_docum...uct/125515.PDF
    Do most people permanently install their sensor or remove it after they are finished logging fuel pressure?
  10. #80
    Oct 2004
    Looks like the 1/4 in. SAE one might be correct. From my reading this seems to be that same as -4an (though I wouldn't trust me on this entirely).
    When I had my LS1 I had the sensor installed permanently. Remember, just because it's there doesn't mean you have to log it all the time if you don't want/need to.
    Andrew
    EFILive Crew
  1. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  2. EFILive AutoVE Tutorial help
    By -=Mod=- in forum Gen III V8 Specific
    Last Post: September 28th, 2009, 03:54 AM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. EFILive AutoVE Tutorial & 1998
    By eboggs_jkvl in forum General
    Last Post: June 19th, 2006, 03:13 PM
  5. Tutorial for tuning VE using LTFT's using EFILive ??
    By Thedude in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2005, 10:55 AM
