I remember reading a post (but not where I read it) that suggested that Lean Cruise did not work with a Mafless tune. Does anyone have any thoughts or data on this?
Thanks, Steve
Thanks, Steve
Just got off the showroom floor, now lets fix it.
That is not true, it still works.
yep agree with ross.my vy ss is mafless and the lean cruise works fine.
Thank you gents, clearly the post that I read was not on this forum. I really like the concept of lean cruise but will wait until I have a wideband connected before experimenting. I have just checked a great log that includes an EGT, that shows the temperature dropping as the AFR leans down from 15:1, so I am confident that it is safe. ( see the post in this section "Is lean burn safe")
Thanks again for the quick response.
I need to go ask the minister for finance for a wideband.
Cheers, Steve
A few of us have issues with using Lean Cruise in OS5. I've never got it to work in the same manner as it does in a GM OS. In the end I gave up and just simply use B3647 to command my lean cruising AFR's.
We actually discussed this issue on the LS1 forums recently.
http://www.ls1.com.au/forum/showthre...05#post1305405
Never had a issue with lean cruise , there was a problem on a VY calibration that does what the guys on the LS1 forum talked about , I found if I used the right base calibration it functions perfectly.
Even GM regulary have errors in the coding , updated calibrations fix this.
I use my own custom version OS that 12900005 was based off , but I have seen the lock in pe mode on a stock OS after exiting the lean cruise routine. GM quite commonly have faulty code - such as the maf freqency dropout on the LS2
I will send my version to Ross to get him to compare the code of each and see if there is a problem ( just add it to the list Ross)
not trying the threadjack or anything but I've also heard that lean cruise will not work in OL at all? any truth to this?
1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
If it's commanded in B3605 it will. The GM-Holden tunes that were validated for the M-East didn't have the Lean Cruise tables activated, but had B3605 commanding up to 16.6:1 in the appropriate area. The earlier M-E tunes were full-time OL.
See tune "2001 Commodore (Middle East) Sedan Automatic ---PCM12202088"
(It actually came out of a Caprice SS) ..........in Holdencrazy.com
