Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 95
Thread: A way to cheat and fix your strims/ltrims using Rtac Very quickly.
  1. #71
    Aug 2004
    Here is an easier route to go to put in the ve fixer. Put this file in your documents folder/efilive v7.5/ user configuration/
    You need to say YES to the overwrite of the calc_pids.txt file.
    Then reopen the software and you will now see the pids under the calculated tab.
  2. #72
    Aug 2004
    You still have to do the instructions to make the linking to work as posted in the 3rd thread.
  3. #73
    Mar 2007
    Quote Originally Posted by wait4me View Post
    The maf can still be put on. It will work fine.
    I've been driving for around 4-6 hours and it seems my vehicle is tuning much slower than you said in the initial post. You said yours fixed the whole VE table within 10 minutes.
    **Edit: I think it was because my update frequency was 10 instead of 1. Changed it now. Going for a drive.
    My truck was really rich. I was previously getting 10mpg. It has been rich its whole life with me. After doing some VE tuning, I'm getting 12.5 mpg. Improvement, but still alot of work ahead.
    Do you use coarse or fine? Did you change any other rates?
    To set this up I followed the AutoVE RTACS tutorial, and then this post. I am using STFT1 only, and no wideband, because I do not have it installed yet. Tuning strictly off of STFT1 and bens.
    I have another question but I save it for my next post.
  4. #74
    Jan 2007
    Hi Eric,
    When I went through this...I started with coarse control and set it to make big changes for the first short drive. Next I set it to fine control and smaller changes to try and taper it in as close as possible.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  5. #75
    Mar 2007
    Thanks Howard, YGPM or You Got PM.
    I'm having much fun with this.
    After I tune the VE, I guess I'll do the MAF next. Wideband soon.
  6. #76
    Member JAY4SPEED's Avatar
    Mar 2007
    I'm thinking about adopting this strategy for my E67. Obviously RTACS is out for me with the E67 with no roadrunner.
    The first question I have is that if I don't plan on using RTACS do I need to worry about modifying the cal link file as it says in post #3? I've built a STFT ve fixer map and plan to apply the ST bens the same as I would with auto VVE so is the cal link file editing necessary?
    Right now I've been doing OLSD VVE tuning. I'm assuming I'd have to enable closed loop and force my LTFT to 0 and allow the short term fuel trims to accumulate and populate my STFT ve fixers map, correct?
    I liked this formula ( ({SAE.SHRTFT1} + {SAE.SHRTFT2}) /2)/100 + 1 from post #69 because it makes sense to me to average both banks together rather than just having a formula for bank 1. However, I'm not quite understanding the "+1" at the end of the formula. Was that something specifically for RTACS to keep it auto adjusting over the nominal trim and allowing the STFT to bring it back down? Would I be better off using the formula ( ({SAE.SHRTFT1} + {SAE.SHRTFT2}) /2)/100 if not using RTACS? I apologize my math skills are lacking.
    Thanks for any clarification!
    Jay
  7. #77
    Mar 2007
    As for the other stuff, ill soon post auto spark table building.....
    This I'd be interested in learning as well. Any updates on this?
  8. #78
    Jay,
    If you're multiplying (and you are) use the 1st formula: (({SAE.SHRTFT1} + {SAE.SHRTFT2}) /2) /100 +1
    If you're adding (and you're not) use the 2nd formula: (({SAE.SHRTFT1} + {SAE.SHRTFT2}) /2) /100
    The 1st formula gives multiplying factors wrt 1.00 (like 1.02 or 0.98).
    The second formula gives additive terms wrt 0.00 (like +0.02 or -0.02).
    See the difference...?
  9. #79
    Mar 2007
    Jay,
    Yes, thank you very much Sir!
  10. #80
    Lifetime Member samh_08's Avatar
    Oct 2008
    Thread from the dead..
    Simple question. Are we supposed to set B4206 to 'disable' so the STFT's are not influencing how much the VE table is actually off?
  1. Emission Testing/Ways to Cheat?
    By onegonewild in forum Gen III V8 Specific
    Last Post: July 13th, 2009, 07:08 AM
  2. rtac question
    By ty_ty13 in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 30th, 2007, 10:05 AM
  3. Why spend time getting ltrims from -13 down to -4?
    Last Post: April 9th, 2006, 12:03 PM
  4. Resetting all telltales quickly?
    By kp in forum General
    Last Post: April 16th, 2005, 01:31 PM
  5. Positive Ltrims In Cell 22
    Last Post: March 17th, 2005, 03:15 PM
