Do you see the Options.ini file under either of these places:
C:\Program Files\EFILive\V8.1\Programs
C:\Program Files\EFILive\V8.1\Config
Drag the Options.ini from the upper pane (one of those 2 folders) to to lower pane (Config Files tab).
Once you have done that you are ready to log (disconnect laptop, restart V2, on V2 select the PCM that is for your WS6 (LS1B_A for A4, LS1B_M for M6).
PM your phone #.
