Page 13 of 26 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 253
Thread: Flashscan data logging..
  1. #121
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Cool, thanks.. Is there a link somewhere to see what all the different abbreviations stand for? Like MFTOTAL.. Dont know what that does/is.
    Also, I got the cable ordered, do I have to add that to the "options" thing to get the wideband AF to show up??
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  2. #122
    MFTOTAL is the Misfire Total... this is the running count of misfires for the current 200 rev cycle of misfire detection.
  3. #123
    Your log shows your 1->2 WOT shift at 3.1-7.5 mph...
    I think you can't set the WOT MPH values that low and all equal...
    You have to spread them out a little, and make them in seqeunce...
    i.e. in this order (increasing mph as you read down the list):
    WOT 2->1
    WOT 1->2
    WOT 3->2
    WOT 2->3
    WOT 4->3
    WOT 3->4
    with each downshift being at least 5 mph lower than the corresponding upshift.
    We have to analyze your log again so we can set those higher and still allow the rpm to control the upshifts.
  4. #124
    Show me your Kickdown Throttle tables.
  5. #125
    Mar 2008
    Here is the tune..
  6. #126
    Jody, what stall is you converter...?
  7. #127
    Jody, I took the liberty of modifying your calibration file...
    Open it with the tunetool and compare with the file you posted (see images for diffing instructions).
Name:	Jodys new tune.png
ID:	4114   Click image for larger version.
  8. #128
    Mar 2008
    Its a 4K stall from Fuddle. With a 2.4 STR.. Its not the best of converters.
  9. #129
    Mar 2008
    Ok... That will tell me what files/graphs/tables were tweaked?
    Im still in the learning curve (more like at the bottom of it) for me and so I can see what you did and how the car responds can only help me in my quest to understand. Sweet.
  10. #130
    Mar 2008
    I found a "history" tab up top and scolled down. So, you want mt to try this tune and see how it performs?
    Oct 22, 2008 13:19:00
    Engine Calibration.Fuel.DFCO
    {B3308} DFCO M6 Enable Temp, changed from "284" to "284".
    Transmission Calibration.Trans Pressures
    {D0701} Base Pressure 1->2 Shift, modified.
    {D0702} Base Pressure 2->3 Shift, modified.
    {D0703} Base Pressure 3->4 Shift, modified.
    __________________________________________________ ______________________________
    Oct 22, 2008 13:23:18
    Transmission Calibration.Throttle Kickdown
    {D0962} 4->3 Throttle Kickdown, modified.
    Oct 22, 2008 13:33:18
    Transmission Calibration.Shift at VSS.Upshift
    {D0910} WOT 1->2 Shift Speeds, Normal, changed.
    {D0911} WOT 1->2 Shift Speeds, Performance, changed.
    {D0912} WOT 1->2 Shift Speeds, Hot, changed.
    {D0915} WOT 2->3 Shift Speeds, Normal, changed.
    {D0916} WOT 2->3 Shift Speeds, Performance, changed.
    {D0917} WOT 2->3 Shift Speeds, Hot, changed.
    {D0920} WOT 3->4 Shift Speeds, Normal, changed.
    {D0921} WOT 3->4 Shift Speeds, Performance, changed.
    {D0922} WOT 3->4 Shift Speeds, Hot, changed.
    Transmission Calibration.Shift at VSS.Downshift
    {D0925} WOT 2->1 Shift Speeds, Normal, changed.
    {D0926} WOT 2->1 Shift Speeds, Performance, changed.
    {D0927} WOT 2->1 Shift Speeds, Hot, changed.
    {D0966} WOT 2->1 Shift Speeds, 4WD Low, changed.
    {D0930} WOT 3->2 Shift Speeds, Normal, changed.
    {D0931} WOT 3->2 Shift Speeds, Performance, changed.
    {D0932} WOT 3->2 Shift Speeds, Hot, changed.
    {D0967} WOT 3->2 Shift Speeds, 4WD Low, changed.
    {D0935} WOT 4->3 Shift Speeds, Normal, changed.
    {D0936} WOT 4->3 Shift Speeds, Performance, changed.
    {D0937} WOT 4->3 Shift Speeds, Hot, changed.
    {D0968} WOT 4->3 Shift Speeds, 4WD Low, changed.
    Oct 22, 2008 13:49:29
    Transmission Calibration.Desired Shift Times
    {D1108} Desired 1-2 Shift Times, modified.
    {D1109} Desired 2-3 Shift Times, modified.
    {D1110} Desired 3-4 Shift Times, modified.
    Oct 22, 2008 13:59:00
    Transmission Calibration.Torque Reduction.Upshift
    {D0801} Torque Reduction 1->2 Shift, modified.
    {D0802} Torque Reduction 2->3 Shift, modified.
    {D0803} Torque Reduction 3->4 Shift, modified.
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
