Results 1 to 5 of 5
Thread: Can You Use Efi Live to Program Remote Entry?
    Jan 2009
    Default Can You Use Efi Live to Program Remote Entry?
    I recently got my 01 Duramax from a wreckers to which we fixed it up and got it recertified and all that jazz. But the remote for the door locks never came with it... I know it had this option from factory.
    Now I have another remote off a different truck... is there any way that I can get it programmed without brining it into the dealer? Im not sure whats involved but it seems like with all the options EFI live has it wouldnt hurt to ask...
    Mitch
    Aug 2008
    You need a Tech2...
    FLASHSCAN V2 & AUTOCAL
    Here's how you do it:
    NOTE: When Remote Control Door Lock Receiver (RCDLR) is in program mode and receives the first transmitter input, all previous transmitters are erased. All transmitters must be programmed.
    1. Close all Vehicle doors. Insert key into ignition. Hold down UNLOCK button on power door lock switch on door panel. Turn ignition on, and then off twice. Release UNLOCK button on power door lock switch. Door Locks should cycle once to confirm programming mode.
    2. Hold down LOCK and UNLOCK buttons on transmitter for 15 seconds. Door locks should cycle once.
    3. Repeat step 2 for each additional transmitter (up to 4 total).
    4. Turn ignition on to exit programming mode. Verify operation of transmitters.
    Jan 2009
    Thanks alot... you just saved me a bunch of $$ for something so easy to do...
    Quote Originally Posted by Mitco39 View Post
    Glad I could help!
  1. Remote Tuning Classes
    By vetteboy2k in forum EFI University
    Last Post: February 7th, 2014, 12:05 PM
  2. LMM - another No remote start after ECM swap
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 8th, 2010, 11:51 AM
  3. Remote Start configuration
    By Max Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 5th, 2009, 04:24 AM
  4. !VATS for remote start
    By warscout2 in forum Gen III V8 Specific
    Last Post: January 19th, 2007, 07:34 PM
  5. remote laptop screen ????
    By Delco in forum General
    Last Post: July 11th, 2006, 01:25 AM
Tags for this Thread
