Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 136
Thread: Beta testing for SF .
  1. #21
    Quote Originally Posted by limited cv8r View Post
    what is the general agenda for this beta testing, just trying to get a heads up on what would be involved.
    Well first you would need to submit an AutoCal beta tester's application, unless you have already and I missed it.
    http://www.efilive.com/index.php?opt...orm&Itemid=135
  2. #22
    Did things start and I missed it, or are we running behind schedule?
    Rgds
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
  3. #23
    Quote Originally Posted by Happy Jim View Post
    Rgds
    Jim
    The beta test started about two weeks ago, the beta applications closed last week.
    Once the beta software is stable/working, it will be made available for download. That should be in about a week.
  4. #24
    Jun 2006
  5. #25
    Mar 2009
    Not quite sure where to post this, so figure I would here where the AUTOCAL has been mentioned. I was talking to a tuner the other day about my conversion I am doing, and he mentioned the AUTOCAL as possibly being a good route for me to take once it's available. I understand this unit allows stand-alone flashing with a tuners pre-loaded tunes, but what else will it do? Will it be able to work with EFILIVE tune tool as well similiar to that of the V2? I'm not looking to do engine tuning myself, I found one I want to do that part. My question mostly pertains to gear changes, speedometer settings, and changing shift points some to match my set-up. It is an 01 DMAX/ALLY that I am swapping into an older body style SUBURBAN and may want to make tweaks to some of the settings to make it all work. Will the AUTOCAL be able to do this, or will I need to get a V2?
  6. #26
    Quote Originally Posted by THEFERMANATOR View Post
    The AutoCal units are designed to be sold to end users and supported by workshops, dealers, resellers. EFILive will most likely not be selling single units to the general public. There will be a number of features that tuners can turn on or off before selling AutoCal units to their customers.
    With the most features turned on (the most expensive option) AutoCal will behave almost the same as FlashScan and will allow full scanning, logging and tuning duties. Obviously it has no external inputs and no SD card so it will be limited in its scanning duties by those missing features.
    With the least number of options turned on (the most cost effective option), AutoCal will perform scanning, data logging and reflashing of preloaded tunes only. In this minimum configuration the end user will rely on the tuner that sold the AutoCal unit to make changes to any tuning parameters.
    So it will really be up to the tuner that you purchase AutoCal from what options you and the tuner decide to activate.
  7. #27
    Mar 2009
    Thank you. Sounds like the right option for me. I don't need any real adjustments for fueling or timing, just maybe an idle tweak, speedometer, gears, and possibly some torque management with a shift point change. Never know how it will react in a different vehicle being set-up for road trips and some moderate towing vs factory built for general useage.
  8. #28
    Nov 2006
    Looks like people will need to get creative to log AFR.
    LC-1 WBO2
  9. #29
    There is a serial option*... but using it requires opening the AutoCal and soldering onto the circuit board. A fairly trivial hack but one that will void the warranty.
    *The serial option (logically identical to the serial port on FlashScan) was required in order to program the Infineon CPU during manufacturing.
  10. #30
    Many thanks for the update Paul.
    Rgds
    Jim
  1. Any News about Beta Testing
    By Ninety8C5 in forum Lounge
    Last Post: March 31st, 2009, 04:04 AM
  2. Testing wireless...
    By joecar in forum Lounge
    Last Post: July 3rd, 2008, 03:17 AM
