The Options.txt file you sent to support has the following headings for the PID Selections Lists:
Code:
;Node PID Custom (Cap:Units:Prec:Fact:Offs:Inv) Alarm (min:max:style:time*10ms:hold*sec)
On the latest version 8 build this format is no longer valid, and has changed to:
Code:
;Node PID Alarm (min:max:style:time*10ms:hold*sec)
I suspect you are perhaps running an old version of the V8 beta (latest is 8.1.2 Build 44), or this file has been brought forward from a previous release and is no longer a valid format.
I would recommend updating the the new V8 version, first removing the current install to ensure file integrity.
