yes, thats the version I'm running, see my post right about yours. EFILive automatically updated me to the latest version.
this sucks. I am supposed to race tomorrow and I wanted to BBL... I need to get this resolved ASAP!
Try this [] sqaure brackets indicate where to do this from:
0. use Scan&Tune to set up an Options.txt with the pids you want to log[S&T],
1. reflash V2 firmware [EE],
2. set time to now [EE],
3. reformat the Config tab [EE],
4. reformat the 2 data spaces (select SD card and internal and format each) [V2],
5. set data space to SD card [V2],
6. copy LS1B_M.pmm (for your 2001 ZO6) and Options.txt to the Config tab [EE],
7. copy the 4 *.dtc files to the Scan tab [EE].
BTW: LS1B_M = 1999-2008 LS1 with M6
You should be good now.
If you want, skip step 0 above and copy the attached Options.txt to C:\Documents and Settings\All Users\Application Data\EFILive\V8\Config.
PM me your phone number and when is a good time to call... (I'm in CA).
Joecar, thanks for the help thus far. I ran out of time today to mess with it, its going to have to wait until Saturday. I'll try what you suggested above and report back.
If you want me to call it has to be before Saturday.
bringing this back up... joecar, I followed your setup above and was able to get the v2 to see the lc1. thank you!
I don't know what was wrong with the V2, if it was a software or hardware issue, but when you would scroll down using the arrow keys it was skipping over more then one option at a time.
also the f1-f4 buttons didn't do what the description said, it was really weird & frustrating at the same time. I hope it doesn't happen again.
pass thru logging seems to be working fine as well.
At least now I can start to record with the laptop in the car and get some A/F readings.
I figured since everything was going smooth I'd try BBL,
I formatted the SD card, selected data logging>record data> but I didn't see any data on the v2.
not sure what I did wrong but, I'm going to look the BBL section and see what I can find...
See post #12: showthread.php?t=10920
ahh, I figured out what I was doing wrong... as usual it was something little.(that smiley is PERFECT)
when the flashscan program opens up, it defaults to the first controller on the list. 98 manual - or something like that.
I was loading my selected PID's into that contorller, which wasn't the one I was picking on the V2.
once I reprogramed my pid's into the correct controller I was able to take my very first of many bbl's: BBL00009.efi
thanks again joecar![]()
