I did a search on this and didn't find anything on this subject and was wondering if anyone else had noticed it.
I was looking at my logs today and noticed the cam phase angle went to 18 degrees at 1650 RPM when the DOD was enabled. I have replaced the "blob" (for lack of a better word) of high cam retard on the cam phasing tables with normal numbers ("0" in this cell) so it doesn't retard at cruising speed. However, it did today when the DOD enabled. Therefore, I "assume" there are some more tables that control this.
With larger VVT cams coming out in the very near future, it would be good to be able to limit all cam timing for piston clearance so you might not have to buy a VVT limiter kit. I would suppose this applies to the trucks also.
Ross, any chance these might get these added in the near future? I am thinking about adding a bigger DOD cam to the L99 sometime soon and it could effect the install time frame.
Ron
